garritynet
- Oct 3, 2008
- 416
- 0
- 0
[Mounting: Swiftech Steel MCB-120 "Radbox" Rev. 1
Rev. 2 is plastic/resin and Rev. 1 is steel. If the paint chips off the steel one it will rust. Trust me, it will. The plastic one is more expensive.
Originally posted by: LOUISSSSS
"You will need the XSPC pump top if you are using 7/16" ID tubing because the standard plastic Swiftech top comes with integral 3/8" barbs and you need 1/2" barbs. These plastic 3/8" barbs are formed into the plastic top and cannot be removed nor replaced."
So after i replace the top of the stock 335 with the XSPC top FOR $20 MORE?!?!? i'll need to attach two more Fatboy G 1/4 1/2" OD Fittings? can someone explain to this noob why i need the XSPC top again?
in that case what are my other pump options for this loop?
Originally posted by: PCTC2
You need to pick up an XSPC top for the DDC3.2/MCP355 (they are the same) because the stock top is only 3/8 barbs. Then you'll need to pick up two addition fittings.
As for fittings, 2 for res, 2 for rad, 2 for the pump, and the CPU block comes with fittings. They will all be 1/2OD G1/4 barbs. DangerDen FatBoys and EK High-Flows are good fittings. Clamps will be 8 in number.
Originally posted by: daw123
If you use the MCP355 with 7/16" ID tubing, the tubing will be too loose on the stock barbs (3/8" OD). You can probably squeeze the tubing on to the barb using worm clamps to make up the 1.6mm difference in diameter between the ID of the tubing and OD of the barb, but do you want to run the risk of it leaking?
Doesn't work. Already tried.Massive leakage. Lots of air and water in loop.
i've updated my OP list of parts, please comment =)
i've learned so much about what i need to complete a WC setup in the last few days, i'm so proud of myself, and thankful for your help.
just some minor questions:
Liquid: Distilled water + Pentosin G11 + ____?____. and what is the correct mixture?
What are some common problems of first time WC'ers? i'd like to be aware of them so i can try and avoid them...
