Here's my take about the results from Cooaler.
Original link:
http://forum.coolaler.com/showthread.php?t=240578
-The benchmark right below Cinebench R11.5 is "CPU Queen"(Result: 30674). It scales linearly with clock speed and is
not sensitive to cache changes. The Sandy Bridge CPU tested has ~5 percent advantage when scaled to Bloomfield core clock speeds. This is right on mark with expectations that while the core is somewhat enhanced, the focus is somewhere else. I'd guess some good branch prediction/front end related improvements are here.
-The next benchmark is called "CPU Photoworxx". It's a multi-threaded benchmark that is
extremely memory bandwidth sensitive. Think SpecFP suite. With page 3 results showing substantial improvement in memory bandwidth, its expected that it performs well in CPU Photoworxx.
-Page 2 shows "CPU AES" results. While the results seem impressive, its because it has a AES-NI instruction set. Core i5 650 can get 198997 in the same benchmark as Westmere cores all have AES-NI. The benchmark also scales linearly with clock speed and it takes advantage of cache changes. The advantage for Sandy Bridge scaled to identical clock speeds/cores/ISA is 10-15 percent faster than Westmere.
-Page 3 shows memory bandwidth related benchmarks. The first result is "Memory Read" while the second is "Memory write". Memory bandwidth results are NOT sensitive to clock speed changes, but rather memory subsystem results as expected. The greatly improved result in the "Memory write" is likely due to the additional AGU on Sandy Bridge.
-The 3DMark scores show some interesting changes for the "CPU" portion of the benchmark. Some scores I have been able to compare shows 15-20 percent improvement over Nehalem/Westmere.
