exar333
Why would a gamer buy sandybridge? That's not what the SKU is designed for.
This is like someone benching Llano or Bobcat but deciding to use SLI-GTX480 instead of benching the Fusion aspect of the CPU because hey there are some gamers out there that might want to see such benches...but that's not an excuse to not bench the part of the chip that defines its very existence.
Even if the performance sucks, from bad driver or bad bios support, its not coolaler job (or is it?) to make sure Intel's prototypes are seen in the best possible light so you'd think a leaker would leak the results as they are. It kinda defeats the purpose of leaking stuff if you only leak the stuff that is pretty much irrelevant to begin with.
As a gamer, I would love Sandy Bridge if it had some sort of hybrid-power scheme for the IGP/discrete GPU. I could save power and use IGP when surfing the web, and then use my GPU when gaming.
I agree though, in general, that part of the performance should be the IGP numbers. It may not be "extreme" but it is an important aspect of the CPU.
