WaitingForNehalem
Originally posted by: Nemesis 1
I read this early this morning. Could you link to were PII kills IC7 in games. I MISSED that!
Also your aware as most are that IC7 getts faster with more GPU power . The PII is a nice little cpu that O/C well. But its not even close to a match for IC7. PII will have to play against Penryn . IC7 is years ahead.
However, they are also in completely different price ranges.
Assuming the £190 price for the Phenom II 920 is what we see retail, the i7 920 (2.66GHz) goes for £230, while the i7 940 is more like £450.
So while the Phenom II may perform worse than Core i7's, it's also cheaper both on a per-CPU basis, and on a per-platform basis (cheaper motherboards, cheaper RAM currently).
For comparison to Core 2 Quad, the Q6600 is about £150 and the Q9450 is about £250.
So it's:
Q6600 £150
Phenom II 920 £190 (approx)
Phenom II 940 £220 (approx)
Core i7 920 £230
Core 2 Quad Q9450 £250
Core i7 940 £450
Which means that overall the Phenom II may be a reasonable choice of product, since really it's competing with slower C2Q's than the 3.2GHz one used in this "test", assuming that the numbers are anywhere close to accurate.
PII will have to compete against Lynnfield (?) i.e. the lower cost dual channel version of Core i7.
Yep it is cheaper and ALL around alot slower. On the O/Cs A few guys are getting 4.4GHz on waterIC7. Until we see real reviews of PHII O/C its not a done deal. Also by your reasoning . O/Cs for both IC7 & PHII must be done at same voltage . The lowewr V. to do the samr GHz. Is winner. Does that sound fair?
My daughter just order 10 of each of these parts. + More.
IC7 920 $299
Memory DDR3 3x2mb. $239/
Motherboard $398
GPU $539.
$ 1475 The first meroms we built were = in cost.
You could save $500 if you get the Core i7 920 from MicroCenter for $250.
