I just built my PC, and everything looks to be connected correctly. When I turn it on, all the fans start up and the speaker emits 1 long beep and 2 short beeps. Nothing shows on the monitor. Heres the specs:
A8N-SLI Deluxe
Corsair XMS 1gb
Sapphire X800
Maxtor SATA 7200rpm 8mb cache
Lite-On 16x DVD drive
Enermax Whisper 2 PSU (550w)
I may have connected the HD LED plugs the wrong way, because they don't light up on the front panel, unless the HD isn't supposed to activate that early in the boot process. I also can't hear if its spinning or not. I have a sneaking suspicion that it might be the mobo, since i double checked all the connections for the video card, ram, ect. Can someone please help me out?
Edit - I just remembered to plug in my headphones, and the mobo said "system failed VGA test"....so what should i do? I though the video card was properly seated but I'm not sure now, nor am I sure of the correct way. I just inserted it into the slot and it fit fine. Theres a small lever next to the PCI-E slot but it doesnt seem to move or anything.
A8N-SLI Deluxe
Corsair XMS 1gb
Sapphire X800
