First GTX1070 review
If you also read the HardOCP review, they say the same thing he did. It throttles but even after the throttling it maintains higher then advertised boost clocks. I don't see the fuss, and this non issue will be even less of an issue with AIB cards.
Really?
This is also on an open air test bench. So inside of a case, like others have shown, it can drop below the advertised boost clock.
All of this is already well documented, I don't know why people are still trying to deny it. In the end, I don't think many will mind making a custom fan target/curve and solving the issue without much added noise, but better to be realistic of the situation and how to deal with it than cover one's eyes and pretend like there's nothing to see.
Really?
This is also on an open air test bench. So inside of a case, like others have shown, it can drop below the advertised boost clock. And also, a well ventilated gaming case could very well remove heat better than an open air case. Unless the open air case had a bunch of fans blowing across it of course. Some reviewers do that.
If it drops below advertised boost clock, its only momentary. As per your graph it by far spends the great majority well above advertised boost clock. And average all second by second readings after 300 second mark and it will be well above advertised boost. I know you see this.
It shows how limited the OC potential is and how "well" the "Premium" cooler works
It also proves that the retail cards do throttle.
That's nothing new with the way Nvidia's Boost works and the main thing here is that it is running well over the listed clocks. 1850-1900MHz or 2GHz is not that bad some are making it out to be. There are few other 1080FE owners they do report no such issue yet. Someone on another thread is getting 2050MHz with ease,not bad.
Yea it's below the hype created by some but still not bad at all. With Gtx 980ti there have been custom Bioses whereas all 1080,FE or custom what we have seen yet are restricted by volt-lock. May be when it is circumvented we might see better results. 🙂
That's way above the listed default boost clocks. Not a problem really then
Computerbase.de did a test in an actual case (unlike most of the other sites that use open air benches).
They found that the 1080 throttles down below it's advertised boost clock in 18 out of 21 games (86%), only managing to hit the advertized clocks in AotS, F1 2015 and MGS 5 (the last one is debatable though). It even throttles all the way down to base clocks in 7 of the games (33%)
Yep, I have seen that mate. All I said was in the context of the 1080FE owners reporting here. If they are not facing this issue then may be there isn't that big a problem that's been made out to. I am not too sure.
Also some people have reported it was down to initial drivers plus there was some fan revving issue which are still looked into. So we will see how it turns out 🙂
The reviews all use 368.14 or 368.16 beta. Retail uses 368.25.
But until we have some actual reviews of these new drivers, I see no reason to suspect that the only test done in an actual case (that I'm aware of), which clearly shows the 1080 FE throttling down below the advertised clocks in the vast majority of games, is wrong.
Is there any mention of ambient temps during those benches? Any pics of the actual open air test bed?
Links appreciated.
I know you said computerbase.de
Looking around now.
Links appreciated.
Looking around now.
Sorry, I should have included the link: http://www.computerbase.de/2016-05/...bschnitt_bis_zu_1785_mhz_takt_unter_dauerlast
Computerbase uses a Fractal Design Define R5 case, not an open air bench. They don't mention ambient temperature, but they have a 950 idling at 23 degrees, but that was probably done previously.
Looking at historical records for the temperature in Berlin in the week leading up to the review, it doesn't look like it would be a problem: https://www.wunderground.com/histor...statename=&reqdb.zip=&reqdb.magic=&reqdb.wmo=.
OMG went there and did you see the ASUSstrix oc review?
http://www.computerbase.de/2016-05/asus-geforce-gtx-1080-strix-oc-test/4/
Noice.. so no worries about founders being the only option. Strix is about 90 euros cheaper too.
Yeah it definitely seems like it's only really an issue with the founders edition.
They tested the 5 games where the Founders edition throttled all the way down to base clocks and the Strix OC did just fine (advertised boost clocks for the Strix OC is 1936 MHz):
The Strix OC still throttles below advertised clocks in Anno 2205, but if it's only one game out of 21 then it's hardly a significant issue.
Yeah a proper review would make it clearer. Or may be some of the 1080FE owners with their own experience would clarify it as more buyers of this card pop up(till now though none of FE owners report such issue here on ATF). Hopefully AT or TR review would check into it while using newer drivers.
Maybe the new drivers kick up the fan profile a scootch?
From my reading, the issue being fixed by the driver was more that the fan was a revving up and down unnecessarily, and not so much that it was running to slow on average.
But I suppose the driver might also tweak the fan profile to run a bit higher on average. If that is the case, then I hope some of the sites out there will retest the noise levels as well.
Somewhat amusingly, this would be similar to what AMD did with the R9 290.
You do realize that the plot is over 30 minutes long, right? So what may look like momentarily can be a significant amount of time while playing a game. Additionally, as I said in the post you quoted, this is an open air test bench and the card can throttle significantly more once inside of a case, as was already shown. The card throttles. It needs a higher fan speed and/or temperature target to not throttle. If you're ok with that, great, but that is the situation. Again, the good news is that reports are that the cards stays pretty quiet, even with a higher fan speed.
http://www.computerbase.de/2016-05/a...rix-oc-test/4/
Edit: thanks antiheltin for the links.
Yep, as predicted, custom cooling solutions have no problem keeping the card cool and quiet and can be had even cheaper than the FE. Anyone wanting a 1080 who doesn't have a compulsory need to have it before anyone else should get a custom card (niche cases such as SFF builds may need a blower).
Its momentary when you consider that graph and how much more time, by far, the speeds stay above reference.
30 minutes. 6 hours, six days.
Average all those clocks together and can you honestly say that the average would drop below advertised boost clocks at all? Of course you couldnt, because it would absolutely not. At least in this example you provided.
Wow the coolers on the stock cards are disappointing. If it was less expensive than an AIB card that is one thing, but being more expensive than a 3rd party card I just don't see the point unless you want a reference card to add a water block to. FE doesn't stand for 'Founder's Edition' it stands for 'Fool's Edition'.
Waiting for the less expensive and higher performing AIB cards is the smart thing to do and much better value.
Anyway, interesting to see on the Strix review that the extra power connector didn't seem to help it OC any. Really does look like 2.0-2.1ghz it the limit for GP104.
That is most likely a software restriction. A second power connector could easily deliver more power than that strix is pulling. Unless im reading the german translation poorly.
Computerbase.de didn't touch the voltage at all (this being because the software wouldn't let them).
pcgameshardware.de on the other hand reported that some extreme overclocker did manage to up the voltage, however it seems to be limited to 1.25 (which should frankly be enough for the average overclocker). At that voltage and with LN2 cooling they managed 2400 MHz, which may sound like a lot, but at that speed it actually loses in performance to a 2200 MHz 980 Ti (max attained with LN2 for that GPU).
What does that mean for the average user?, well if a 1080 can "only" manage 2400 MHz on LN2, then 2000-2100 MHz is probably the limit on air and water.
PS. this may have been with the founders edition, not really clear from the article.
all this talk about throttling with the FE cooler and in 1-2 months when there's ample supply of custom 1070 / 1080s, people will stop caring to bring it up
Titan X cooler throttled and people stopped talking about that once 980 Ti got released in mass
