First GTX 670 review(s) up (tt & oc.net) * TT OC review added*
the 670 seems to be making my 680 purchase look like a dumb decision!! Tell me theres something more to the 680 than just being 100 bucks more...
I don't think AMD will ever enter into unlocking business again,6950 unlocked to 6970 was pretty bad for 6970's sell.I think they have laser cut the shaders this time.
670 custom is the vfm high end card no point spending nearl 100% more for a sub 10% performance diff, though if 680 oc is 10%+ better it will have many takers
Why doesn't amd just start giving away free money as well? Having cards unlock is the dumbest idea ever
They are going to have to do something. In a matter of 3 days, a GTX670 $399 will make HD7950 irrelevant. If custom GTX670 OC come out at $430, 7950 would likely need to drop to $360 or maybe even $350. Of course AMD can choose to do nothing and hope GTX670 is also OOS shortly after launch.
If custom 670s mimic the results of those 2-3 Gigabyte OC cards at OCN, then HD7950/7970 and reference GTX680s won't look so hot.
You mean $100 more? 😛 100% more would be like $800.
Someone got 1401mhz GPU Boost on yet another Gigabyte GTX670 OC.
Someone said GK104 is a crappy overclocker?....:ninja:
Damn if these cards can consistantly clock over 1300mhz it looks like I may be switching cards again. lol
Depends on how good NV's yields are, if its "lower than expected", there should could be more gtx670 skus than gtx680. 😉
FTFY. It depends on why yields are low. The chips could just be borked. Although I understand that's not likely. Just saying that we don't know what availability will be. The problem could be more wafer starts than yields?
Looks like Gigabyte GTX670 OC is identical to the GTX680 OC version. That means two added phases for the memory subsystem over the reference 680 -- thus that's a 4+2 phase design for their GTX670 OC card. It has also retained the 6 + 8-pin power connectors from the 680 OC version compared to 2x6-pin for the reference 680:
GTX670 OC heatsink/side profile
GTX680 OC heatsink/side profile
imageview.php
GTX670 OC power connector
GTX680 OC power connector
imageview.php
Identical PCBs.
GTX670 OC PCB
GTX680 OC PCB
imageview.php
GTX670 OC = GTX680 with 1 SMX cluster missing. The reference version will have 2x6-pin and prob. won't overclock this well.
Looks like Gigabyte is using identical GTX680 OC PCB with two added phases for the memory subsystem -- thus that's a 4+2 phase design for their GTX670 OC card. It has also retained the 6 + 8-pin power connectors from the 680 OC version:
GTX670 OC
GTX680
imageview.php
GTX670 OC power
GTX680 power
imageview.php
Identical PCBs.
GTX670 OC PCB
GTX680 OC PCB
imageview.php
Can it be unlocked into a 680? :awe:
I wonder what the price of one of these will be? If that little 1/2 length PCB is going to be $400, how much will it cost for a full grown adult version?
Think the 680 version of this card had a max power limit of 111%,same for this?
where are you getting that from? the cards that have 6+8 pin usually have 150% max power limit. it would make no sense for an oced 6+8 pin card to have less than the 132% of the reference card.
VRzone review,and a few users who own the card.
Nope, I would any day take a 7970 over it at $400. Once both are overclocked the 7970 >= 680 at 1440p with MSAA. This thing will be a good 10% slower at those settings.
If this thing is 400 bucks, then the 7970 should be 400 bucks too.
And 7950 should be $300.
if it becomes the crystal clear winner by dropping the price that much, the price has simply dropped too low.
$450 for the current 7970 and $350 for the current 7950 would be fair. Maybe $500 for a 1GHz edition 7970.
Has anybody noticed this yet, a 670 OC @ 1400 core scores X3400 in 3D Mark. A 680 at 1150 scores higher and even my 7970 at 1175 scores a bit higher than this.
So a 680 at 1150 is going to beat this probably by scoring 3400ish as well. So 680 at 1200+ or 7970 at 1200+ are both going to best that thing by a good 5-15% (avg 10%) even if the 670 is at 1400 Mhz which itself is not sureshot even for custom 670s I guess.
I would hold my judgement until i see some actual game benches,i don't care much about synthetics :biggrin: Legion is different though 😉
3DMark is synthetic crap and therefore doesn't reflect anything real.
Use a wide variety of games if you want something accurate.
