Firefox 43 64 bit
jkauff
583
13
Easiest way to confirm you've got the 64-bit version is type "about:" in the address bar. All the build info is right there.
A5
4,902
What's the purpose of a 64 bit browser when a 32 bit browser does the same.
In theory, building in 64-bit mode lets the compiler count on some extra registers being present in the CPU. It sometimes translates into minor performance gains.
thecoolnessrune
9,673
583
Because computers are 64 bit and have been 64 bit with 32 bit backwards compatibility for over a decade now. We need 64 bit Firefox for the same reason we needed a 32 bit Notepad. Eventually, we need to get programs all running in a 64 bit world.
TheRyuu
5,479
14
Security is one reason. You gain additional things when moving to 64-bit such as HEASLR (high entropy address space layout randomization) and always on DEP.
postmortemIA
7,721
40
FF 43 - more pocket ads, forces new search mode with single search engine (same as in Chrome).
I've finally stopped using it for good.
SparkyJJO
13,357
7
A far more direct way of confirming whether your version is 64-bit, run it, and run Task Manager to see whether its process is labelled as Firefox.exe *32 or just Firefox.exe.
IIRC Win10's TM doesn't tell you about 32-bit processes, so run Process Explorer, right-click on the process in question and click on Properties. 'Image' will say 32 or 64-bit.
Win10 task manager is the same basic thing as Win8 and it has (32 bit) marked next to 32 bit programs.
TheGardener
1,945
33
56
I can't believe that Firefox is now harassing me for donations every time I launch the browser now.
Thanks, but I've looked at their latest IRS filing, and they are making a hell of a lot more in income than I am. If Mozilla really needs more cash, perhaps they should stop paying their director $220K a year.
http://990s.foundationcenter.org/990_pdf_archive/200/200097189/200097189_201312_990.pdf
Anyone else seeing this? If so, it is a good reason to keep an older version.
ultimatebob
25,134
2,450
I wish that I would have made it up:
balloonshark
7,325
3,742
Mine opened my home page and a tab like in your pic. I closed that tab and removed a little bit of code at the end of my homepage url. I did this where you set your home page and everything works normal now.
To be clear my homepage is https://duckduckgo.com/ and I removed the junk that was after .com/
I have no idea if just closing the nag tab or removing the code fixed the problem.
TeknoBug
2,084
31
FF 64bit has been pretty good so far, good enough that I removed Waterfox.
But that donation nagging... what the f-, haven't gotten that.
Joepublic2
1,097
Why my firefox is too slow and always hookup my PC?
It's a primitive browser that does all its heavy lifting in a single process. This is why the UI stutters/hangs when it's rendering a complex (or lots of simple) web page(s). See:
https://developer.mozilla.org/en-US/Firefox/Multiprocess_Firefox
In current versions of desktop Firefox, the entire browser runs in a single operating system process. In particular, the JavaScript that runs the browser UI (also known as "chrome code") runs in the same process as the code in web pages (also known as "content" or "web content").
postmortemIA
7,721
40
Oh come on they have plugin handler running in a separate process :D
On a serious note, they use threads, albeit not optimally, because I never can see Firefox use more than one CPU effectively, not even when multiple tabs are loading.
