My Kingston ValueRam PC2700 won't run at PC2700 (DDR333) at all. The highest FSB I can run is 150MHz. Higher than that and I get failures in Prime95, MemTest86, and 3DMark2001 SE Build 330. This memory was previously used on my trusty Epox 8K3A+ rev. 2 and it ran at DDR333 at the fastest timings the 8K3A+ offered. So I know the memory is fine.
Several other members at AnandTech Forums are having the same troubles with Kingston and Crucial memory. Many of these users used the same memory on other motherboards successfully also. We believe that there is a memory timing issue at the root of the problem (or something of that nature) and we want Epox to know about it so that it can be fixed ASAP. We bought our 8RDA+ motherboards so that we could run at DDR333 or faster using components rated to run at DDR333 or faster.
Please make an effort to troubleshoot the problem and see if it can be fixed with a BIOS update possibly. I love this board otherwise and I want to use it for a long time to come. Thanks for reading this and thanks for any help Epox can be in fixing this issue. Here is a link to a thread I started at AnandTech Forums, you can read it and see what I went through and what I did to narrow down my problem. (I am SeekingTao by the way)
http://forums.anandtech.com/messageview.cfm?catid=29&threadid=998712
Kind regards,
Jeff XXXXXXXX
Originally posted by: webley
Actually i got mine from MWave. Newegg is great at RMAs though. Do you think trying a new 8RDA+ could help?
How long do you have to RMA your board webley?
Originally posted by: mboy
What are your mem timings at? I would run them rather relaxed as I dont have much faith in that ram Oc'ed and at tight timings.
Onboard NIC is not a problem as I am using it on mine @ 200fsb
Keep your vcore@ 1.775 and your vdimm at least 2.77.
I would also reco some better cooling on your CPU, but I dont think that is your problem.
I bet it is your ram.
Before my twinmos/winbond (which I cant praise enough), I was using my old crucial pc2100. Even tho it ran at 145fsb @ cas2 in my 8kha+, it wouldnt run that on the 8rda+.
Obviously it wasnt my 8rda+ or xp2100, casue I am running my mem in synch @ 5-2-2-2 @ 200fsb x 11.5
Finally happy with my EPoX 8RDA+
Have you verified that all the cabling is connected properly? I know it's basic but when I have issues I always eliminate that first. PSU plugged into 120V source, ATX header connected, case wiring connected to the right pin blocks, CPU HSF plugged into CPU fan header on the mobo, etc...Originally posted by: HardwareAddicted
Any ideas ?
~ Mark
Any ideas ?
~ Mark
Also, is the RAM seated properly? Have you tried to clear the CMOS by any chance? And if this is a new build (please don't take offense) is there a switch on the outside of the PSU that might be in the "off" position? That has gotten me once before, I was really embarrassed too.
I'll see if I can come up with more things to check. Good luck.
OK, have you tried to clear the CMOS by any chance? I believe that the FF code on POST with no POSTing is one of the signs of a dead NF2 BIOS. Hopefully a clear CMOS can clear that up. If not, an RMA is in order.
