I am going to activate my sisters Nexus 4 soon with T-Mobile. How do you start the porting process?
Do I activate the SIM first? Or do I call them and let them set it up? She doesn't want to lose her number.
What s44 says is true, though. You can forward calls from GV to T-Mo but not the other way around, so 100 minute talk time will be used up very quickly if you don't plan ahead. I have discovered something else about my plan but it's probably too good to be true for many others so I'd rather not brag about it. :biggrin:
I like this battery graph thing, that's pretty cool. My signal is all green right through as well, but it helps that I'm INSIDE the CO, and there's a tower right next to the building.
1d 1h 38m on battery and I'm at 55%. Screen seems to use a big chunk though despite not being on all the time. 32%. Wifi is next at 16%.
How did you get such a crisp picture of the display, is there a way to actually take screenshots?
How exactly is it that your phone's screen is on, but your phone itself isn't awake?Once you enter SIM number and activation code, as well as your old number and its account number, you will be presented with available plans for you. Choose the plan then it will ask if you want a new number or want to port over the existing number. I simply entered the existing number and its account number, and the next morning the transfer was done.
Anyway, the phone's battery life is no issue for me at this point. Frankly I was disappointed the first few days, but its behavior has dramatically changed since then.
I am still clueless of what "Awake" means. Does anyone know?
Press and hold power button and volume-down button simultaneously. And go to the Gallery. If you have a file manager it's under pictures -> screenshots.
I wonder if "Awake" is 'throttle'? If you look at my graph you can see the battery usage was most steep during that period. As the graph shows I was using the phone quite actively throughout, setting up GV, Groove IP, and many other apps and security stuff.
I don't think "awake" is throttle. Here's screenshot of my stock 4.2.1 Galaxy Nexus use today.
You can see in the middle where the battery takes a big dip and and the screen was on but it doesn't show "awake". That's when I played Zen Pinball and Ski Safari. If "awake" is throttle, my phone should have been awake since Zen Pinball is pretty taxing game.
Oh, and notice the signal strength difference between my current JB picture and the old ICS picture. JB picture is AT&T and ICS picture is when I was with T-Mobile. If I could get reception like lopri is getting with T-Mobile, I would have never left and still be with them.
The consensus seems to be that Wi-Fi is easier on battery than mobile data (3G, HSPA, 4G LTE). I want to check it out just by how much on my Nexus 4. On my Nexus 7, adding a SIM did measurably impact the battery drain (i.e. faster drain).Wifi seems to eat up the battery quite a bit too. I was down to 20% so I turned it off and it's a straight line now. So probably a good idea to turn it off when not actively using it and just turn it on as needed. Though I'm going to want to setup some kind of alarm notification system for my server and home environmental stuff, so for that I'll need to leave it on all the time. I also wonder if there are apps or the OS itself polling a lot for updates and what not. I'll have to check my firewall at home for traffic for kicks to see how much traffic the phone produces when idle.
OMG yeah T-Mobile totally sucks in your neighborhood. I don't know the thresholds of color changes in the graphs, but that certainly doesn't look too good. Did you happen to check whether JB improves signal (compared to ICS) on the same device before you moved to AT&T?
Is there any reading material I can find on this topic, written in an analytical/scientific manner?
