MajinCry
How did you get these numbers?
Boris' Fallout 4 ENB thingy. Doesn't do any graphical shiz yet, but it allows you to see the number of draw calls being made.
diamond city in not brutal at all at cpu.That scene is far more demanding than diamond city.
So far only skylake was able more than 60fps in that scene.
Resolution dont matter.Just be sure you are not GPU limited.You can lower resolution to 720P but keep max details.
With my GTX 970 1500/8000 in 1920x1080 all max i am at 85% GPU usage with 6700k 4.5Ghz and DDR4 3000Mhz.
well i dont have data from haswell-e yet.I hope someone with haswell-e can test it.AMD drivers have bad cpu overhead so they have very bad results other results are with Nv GPU.
Results so far:
NV cards
6700k 4.5Ghz 3000DDR4 cl14 70fps
6700k 3Ghz 3000DDR4 cl14 54fps
Xeon 6core sandy bridge 4.3ghz quad channel DDR3 1600cl9 52fps
4670k 4,7Ghz 2400DDR3 cl11 52fps
2600K 4.5Ghz 1600DDR3 cl9 49fps
3570k 4.2Ghz 1600DDR3 cl9 43fps
AMD cards
4930K 4.4Ghz quad channel 2400DDR3 cl11 + r9 290 33.3Fps
I7 4820K 4,2Ghz quad channel DDR3 1866 + r9 290 28fps
AMD FX 8370E 4,5GHz 1600DDR3 cl11 + r9 290 22fps
It is not driver overhead and your own number prove it. Quite the opposite, it seems nvidia gets better boost with faster CPU.
Your conclusions neeed to be backed up by the data you post. Doing contrary is IMHO the wrong way to do it.
All his data supports a CPU bottleneck.
Its cpu overhead
CPU overhead=GPU drivers cant utilize full potential of cpu=low fps in cpu bottleneck scenes.
FX is a beast then, only Haswell has only 30% better IPC. Go get them FX CPU while they last.
No its not, the FX is a turd in this game. As expected being such a weak CPU series.
Say what?! Then so is haswell and ivy. I guess those two with dual channel 1600mhz memory would be slower than his fx.:thumbsup:
Their results are always way off from all test done. They hardly even test. They show what they THINK the results should look like.
Also, their test was made with nv gpu if you didn't noticed. "Geforce GTX980Ti" in polish translates into Geforce GTX980Ti in english.
We have user data that proves fx performs almost as good as ivy and haswell at the same clocks speeds and core counts. Most of the advantage for intel comes from faster memory.
Try harder.
What does GTX980TI have to do with anything?
I don't know, you started posting GTX980ti CPU scaling results when we were talking amd driver overhead. Desperation or what?
I think you need to check the results again. Your Red Team membership clouds your judgement again. FX also tends to perform better with NVidia drivers due to the multithreading. Its not for fun AMDs own GPU division dont want to touch FX CPUs.
So no one here have fallout4 but everyone discus it or why you dont input results can i ask?
like rally its best to test it and we all can see and compare results in very CPU bottleneck scene.
but instead you all just put here one or another graphs:\
Or its too hard load save game take screenshot and put here results?
game is running at 43-44 FPS with this SS
look a little down and it gets back up to 60
look up with a whole lot more visual stuff and back up to 60
The numbers are against you. Clearly faster CPU help nvidia more than amd i latest games:
