Extremely slow wifi using Cisco Valet M10!!!
sdifox
100,276
17,902
And do you have cable TV? Did you use signal splitter on the incoming connection? It will degrade the cable signal.
Unless he moved it, the tech would have installed a proper line or proper booster.
sdifox
100,276
17,902
op, forgot to ask, did you ever run a wifi scanner to ssee which channels are crowded around you?
AnonymouseUser
9,943
107
Not really, but they do degrade over time, especially if exposed to the elements. I would recommend replacing the outside splitter (~$5 @ HD/Lowes) and see if that helps.
Otherwise, try using OpenVPN and VPNBook to make sure you aren't being throttled by your ISP.
swchoi89
200
How do you do that? But I live in a townhouse so I suspect there are not too many interferences.
What kind of actual speeds are we talking about here?
I'm talking about 6mbps to zero, most of the time being zero. Average, maybe 0.5 mbps. This is the cycle: 28 seconds of no internet connection whatsoever, then 2 seconds of sudden internet speed at 6mbps, then goes to 28 seconds of no speed again, cycle repeats.
swchoi89
200
I highly doubt that my ISP is throttling my speed. I had them check remotely on the connectivity of my internet and they said it's fine. So I suspect it's the stupid router.
sdifox
100,276
17,902
You live in a townhouse, I guarantee there are interferences :biggrin:
XavierMace
4,307
450
Not trying to be a jerk, but I didn't know you could get cable internet that was that slow. I get more than that off my cell phone. Which of their plans are you on? I see they've got 5/15/30/55 in most areas. If you're paying for anything above 5 and you're only getting 6, I'd complain to them.
But, I think you may be over estimating how much bandwidth you have. 6mbps is almost nothing these days. I use 12mbps or more from Steam and Battle.net downloads. A single Netflix stream hovers around 5mbps. Meaning both of those will use 100% of your available bandwidth. That's only one user. Have a roommate/family/etc, yeah, just multiply that by the number of people. Guess what happens when a connection is overutilized? It runs like crap, in which case you have 3 options.
1) Get a faster connection.
2) Use less data.
3) Setup QoS on your router.
The router is easy enough to rule out. Plug your computer directly into the modem.
mxnerd
6,799
1,103
Although I don't recommend this, but you can hook up the PC directly to the modem like what XavierMace said, be sure load public profile on the connection and turn on firewall/anti-virus, test it for the shortest time to make sure it's not Cisco router's problem.
AnonymouseUser
9,943
107
If you don't connect directly to the modem to test, then there is nothing else anyone can do to help. You need to help us to help you.
swchoi89
200
2) Use less data.
6mbps is not too bad.... thanks for the detailed comment but I know what speed I'm getting and I had the pleasure of testing it out at two different places, where at the townhosue is expericing slowdowns where my condo isn't.
I was also not entirely clear on this. Is your problem just wireless, or are you having slowness with your wired connection too?
Wired connection is fine I believe, at least I was not experiencing any slowdowns but I might have been lucky.
I already did. I test out using speedtest.net and it's normal.
As soon as I reset everything and reconfigure, use wifi and speedtest.net is normal.
The speed seems to be NORMAL at most times. The only time it's slow is when I'm at heavy usage (i.e. download, streaming). If it's just as simple as loading a website, it's somewhat manageable.
swchoi89
200
And I would imagine there would be even more at a condominium. When I test it (actually, I live in the condo, been her 3 years) at the condo, there is ZERO interruption (with the exception of power outage obviously).
I already did. Hooked it up to the modem DIRECTLY and tested the speed.
The speed reduces down to what I'm experiencing now, as soon as I start using it heavily.
And no, 6MBPS is not THAT bad of a speed like someone above kind of alluded to?!. I can get by streaming all videos on YouTube.
sdifox
100,276
17,902
get a new router.
sdifox
100,276
17,902
did you scan what wifi channels are occupied?
sdifox
100,276
17,902
Actually, you said direct to cable modem is also slow? Check for malware.
