OverVolt
To be fair, they created a supply chain to mitigate other things, not just cost. Companies make mistakes no doubt, but typically they make more right than wrong. If a company did more wrong than right, they should go bankrupt. If that dont thats a separate issue.
It only takes 1 company to make the right decision to make the others follow.
So like for example they threatened to "take their toys and play elsewhere" which would've been suicide for Boeing but they don't seem to care and think they can just hire inexperienced people to do the same quality work.
Then they spill fuselages into the bottom of a river. I think you're overestimating the definition of "created a supply chain"
They moved a factory to North Carolina for tax breaks and because it has lax workers rights and this is the result: http://seattletimes.com/html/businesstechnology/2023913654_boeing787productionxml.html
According to employees, when mechanics removed the cradles that held the rear fuselage in place on Dreamliner No. 214 — destined for Royal Jordanian Airways — nearly 100 improperly installed fasteners clattered to the factory floor.
After landing some good contracts Boeing felt it was in a good enough position to twist the arm the Machinist Union: http://www.nytimes.com/2014/01/02/b...highlights-rift-in-machinists-union.html?_r=0
So after 2008 you could save money without sacrificing quality with cuts to excess workers or benefits and companies had been doing this for years. Cutting is all they know now. Except we are beyond the point where cuts yield a benefit and instead they are just screwing up and costing themselves more money. A couple companies are doing this, like Walmart never having enough cashiers. Or Mcdonalds constantly playing with its menu now to save money, etc. I'm sure on the manufacturing end its likely happening with GM and such we just don't hear about it, although I guess the recalls are telling.
I'd bet they were already behind on production considering the constant mishaps and the moved factories not able to meet quality/quantity Boeing was expecting. Guess thats what happens when you try and cheap out on aeronautics manufacturing. This is something that was bound to happen since cutting is all companies know how to do anymore. Cutting the excess in 2008 was the obvious thing to do but there is such a thing as cutting too much and causing screwups that cost you more money in the long run.
