I have a evga geforce 7900GT 256MB.
I recently downloaded Rivatuner and ATItool in order to overclock it and view the temperatures.
I was amazed to see that when in ATItool I activated the "Show 3D view" or "Scan for artifacts" the temperature went up to 73-74C Celsius! On default speeds!!! Ideals very high as well at 57C.
Is this possible or normal?
I am not able to raise the Voltage for my GPU from the BIOS, there is no option on my very bad for OC board (ECS P965T-A).
I had tried to overclock to 540/864mhz but was afraid to fry the card!
Now it's running on default speeds and still very hot, is there something I can do? I am using both Riva Tuner and ATItool, maybe I should download the NVIDIA nTune? Will it be better?
Anyone had the same problems or heard of with his card?
Thanks
Thanks
