Originally posted by: TripleAAA
Originally posted by: Ricemarine
Yeh. I got a question for the OP 🙂...
Right now I'm wondering why a lot of players use overgrips... Is it because its more squishy?... What is the point of actually using an overgrip?...
Right now, I'm using the head hydrocontrol replacement grip, and my thumb is getting blisters again, so I need something good (unless my grip is bad...). I don't know my NTRP rating sadly... So I'm wondering if an overgrip might be worth investing in... Or probably try a different tacky grip such as the prince duratec.
Right now I'm using a Dunlop 200G Mid with 16G ashaway crossfire II's, strung 58/64.
Also... I've been experiencing tennis elbow lately... Is it possible the frame could be to blame?... Or should I try lowering my tension?...
Overgrips are generally used by players who want a constant "new", "tacky", feel. Since most overgrips come in packs of 3 (or larger bulk reels), you can keep a pack in your bag and during changeovers or between matches, quickly wrap a new overgrip over your existing grip. For players whose hands get really sweaty, this tends to help quite a bit since the moisture tends to transfer to the grip over time. Some people use them merely to build up their grip to a larger size. There are tons of grips out there which means plenty of experimenting to do.
As for your 200g, what is most likely causing your problem are several things. First off, your 200g has a very dense string pattern which doesn't allow for a lot of forgiveness or "pocketing" of the ball on the string bed. This translates to more of that vibration/shock going up your arm. Combine that with the string you are using (Ashaway Crossfire II) which has kevlar in the mix, and you got a very "board-like" feel. Some people like this though and you can argue you get better control with those attributes.
One other thing I should note is your string tension. You stated 58/64 which if correct, means you are stringing your crosses at a significantly higher tension that your mains. Even though your crosses are a synthetic gut, you can potentially damage the frame with that much of a tension difference. Then again, the 200g is a pretty solid/heavy frame so it can probably withstand the pressure pretty well.
With regard to your arm problems, I would suggest trying polyester if you like stiffer feeling string. However ultimately if your arm problems persist, I'd move away from the aforementioned strings all together. Sounds like you might be a string breaker in which case, going with a thicker 15L with a softer construction might be your best bet. If you got the cash to spare, give some natural gut a try. Although I must warn you, if you try it, you might not want to ever go back to a synthetic again.
