Asus P4PE, P4 2.4 (not overclocked) with stock HSF - Idle at 35°
System at 23°
After an hour of UT2K3, my cpu is about 48° - not that hot, but it seems like that is a big jump, no?
Thing is 56c under load and has been on very nearly constantly for like 2 years now (I render a lot of home movies) Thunderbird 1.2. Not overclocked 95% of the time.
I've tried to make the thing cooler, 6 case fans blowing heat, switched retail fan it had for 1 year with Thermaltake Volcano heatsink, temperature did not change.
But as I say its been running for 2 years that hot with 0 problems. so...
my cpu paste/as3 is not applied correctly right now, so my system shuts down :Q when it hits 60C. right now 50-51C with a OCZ Goliath heatsink with 60mm ttake fan. replacing with HAC-V81 X-Dream tomorrow.
Asus P4PE, 1.8A@2.6 temp shows 35C for CPU and 22C for mobo. Alpha PAL on chip with just a red LED fan , I have an panaflo but haven't put it on the Alpha yet.
Athlon XP 2000+ with the dynatron retail fan and heatsink.
cpu 46c idle 50c load motherboard 24c
Msi K7T Turbo LE
Antec sx 1040 case 4 80mm sunon 42cfm case fans.
Same cpu and cooler in the same case with an MSI K7N2-L Nforce 2 board
Cpu 53c idle 61c Load Motherbord 33c.
I think that certainly illustrates just how much board readings can vary on cpu temp.
I am assuming the the readings from the turbo board which used a socket thermistor were just way to low and the K7N2-L readings are much closer to the mark and taken from the onchip diode. I'm a little skeptical at the A7N8X boards temps. They just seem to low for diode readings from the die surface.
System 1
32 celcius. P4 1.6GHz @ 2.4GHz. Retail P4 cooling.
Jumps to 57 celcius under full load though 🙁
ASIII
System 2
35 celcius. AMD Athlon 750MHz @ 1.13GHz. Goliath heatsink with 80mm fan adapter sporting a Vantec Stealth 80mm fan.
43 Celcius under full load 🙂
System 3
65 Degrees Farienhieght. P4 2GHz @ ?.??GHz. Alpha 8942 sporting a 80mm Vantec stealth.
Temp under load...???
Must finish building the system.
