SlitheryDee
I have indeed done this. Anything not typically related to audio transmission that has some persistent tone will usually have me trying to match it vocally. Not really sure why I do that.
What's with all this kiss-up and internet flirting. How do you guys even know if Rubycon is Hot and worth flirting with? Or is a GUY?
Hot avatar + smart + lots of cool techie posts = She's real to ME dammit!What's with all this kiss-up and internet flirting. How do you guys even know if Rubycon is Hot and worth flirting with? Or is a GUY?
I don't hum at things that hum but I sometimes meow at my cat. Does that count?
Used to do that all the time while working on avionics in the Navy. Aircraft use 400HZ power which is a flat A (440) above middle C.
you were your own noise cancelling headset, cool!I was once in a car where the exhaust exited underneath between the front seats. You had to hum in order to prevent brain damage from how loud it was. The humming really reduced the amount of volume you heard... it was rather amusing.
Only if the meow resonates
Do you purr back to your cat?
It's best to project the sound of the meow into a fan!
You're not from around here are you?What's with all this kiss-up and internet flirting. How do you guys even know if Rubycon is Hot and worth flirting with? Or is a GUY?
😱Yes. 🙄Do you purr back to your cat?
I was looking for that joke...well played M'aam.Neither because I do know the words. 🙂
You're not from around here are you?😱
Although she might be a bot.
You know like a noisy electromagnetic ballast, vacuum cleaner, even the noise of tires over the screen part of a drawbridge.
Always tune up, down a little louder but not enough to drown it out. The harmonics you hear sound wonderful! :awe:
If you've never tried it, do it and see what you've been missing! 😀
