Ethernet connection issues with old PC
Bob Hart
Hi Everyone,
Just joined this very busy forum and I'm hoping you can help me with a tricky issue.
I'm in the UK and have broadband connection via Virgin and have a Super Hub, which does both wireless and Ethernet. I have various laptops, tablets and smartphones connected via the wireless section and I've also used the ethernet cable connection on my laptop and TV.
Now I have an older PC which I used to use via Virgin a couple of years ago with no problems and I thought I'll just connect it up to an Ethernet cable from the Super Hub and have a play with it. I want to lend this to someone who doesnt have a laptop or PC and it will get them reconnected to the Internet. They have the same Virgin Super Hub as me.
But I cant get connected to the internet, no matter what I try. Local area connection is connected etc. The cable is connected both ends, there is a light on at the Hub to say this. I've checked through just about every software set up I can and tried the Virgin online help, all to no avail.
So I'm hoping someone here might suggest something I havent tried. The PC is running on XP.
Appreciate any advice you guys can give, thanks
Are you sure you have DHCP configured on your old PC, and not a static IP address ?
My Network Places> click on "show network connections" in left
Click on "local Area connection"
A window pops up
click on "properties"
another window pops up
highlight "Internet Protocol (TCP/IP)"
in window in the middle
Click on "properties" button below window
In the "general" tab of that window, be sure that
"obtain IP address automatically" and
"obtain DNS server automatically"
are selected.
Select OK on the windows on order and close the last one.
EDIT: It is all in the link above your post.
Sometimes a malfunctioning wireless router will have connection issues on the wired sides if the wireless side is not functioning very well. My bet is that the router is not working. Wireless routers are notorious for going bad. I think that is where I would start.
A window pops up
are selected.
Thanks SkyKing,
Checked and it was already set up like this, so it didnt make any difference
Thanks Piasabird,
Router seems fine as described in my original post
if the cable itself is ok (precluding a Layer 1 issue), it could be a Layer 2 problem. Has the NIC given problems before?
Also, DHCP means Dynamic Host Configuration Protocol. it is a protocol used for assigning IP addresses on a subnet without an admin intervening. All routers have this ability to assign nodes addresses without an admin doing so. if DHCP is switched off, then it lends to not all hosts receiving a local/private address, and this is needed for basic internet connectivity.
I sound geeky, but a major part of my job is TCP/IP so it figures lol..
start>run>cmd
type ipconfig /all
post results here..
Thank you, results as requested:
Host Name: The_Harts_PC
Primary Dns Suffix: (nothing shown here at all)
Node type: Hybrid
IP Routing Enabled: No
WINS Proxy Enabled: No
Description: Realtek RTL8139/810x Family Fast Ethernet NIC
Phisical address: 00-01-6C-32-53-9C
Dhcp Enabled: Yes
Autoconfig enabled: Yes
IP Address: 192.168.0.3
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.1
DHCP Server: 192.168.0.1
DNS Servers: 194.168.4.100
194.168.8.100
Lease Obtained: 08 January 2013 18;06;41
Lease Expires: 08 January 2013 19:06:41
IP routing says 'No', is this anything???
Bob, can you successfully ping either of your DNS servers from that PC and get a response?
i.e., go through start>run>cmd
Then type in the command prompt- ping 194.168.4.100
OK pinged it with the following on screen:
pinging 194.168.4.100 with 32 bytes of data:
reply from 194.168.4.100: bytes =32 time=11ms TTL=251
reply from 194.168.4.100: bytes =32 time=8ms TTL=251
reply from 194.168.4.100: bytes =32 time=10ms TTL=251
Ping statistics for 194.168.4.100:
Packets: sent = 4, received = 4, lost = 0 (0% loss)
Approximate round trip times in milliseconds:
Minimum = 8ms, Maximum = 11ms, Average = 9ms
Roughly the sae result for 194.168.8.100, except times were slightly longer
Excuse my ignorence, what does this mean? It seems to imply it's all OK, as it's getting back what it sent???
OK thought I'd try something else just to check.
Turned wifi off on my laptop and used ethernet cable instead - couldnt get a connecting. Did ipconfig and DHCP wasnt enabled. Checked and obtain ip address and DNS server were set to automatically???
Pinging obviously didnt get a return
On old PC tried pinging without the ethernet cable connected and didnt get a return
Confused.com
Do you have another PC that you can download Firefox (or Chrome, etc) from? Take that file and install in on the XP PC and try again? It's possible that the Internet Explorer is hosed up? (I have seen this on a friend's PC in the last few weeks).
Another possibility is that the TCP/IP stack is messed up and usually deleting TCP/IP and reinstalling it might fix it. However, I don't think that you can ping (not sure) and your ping seems to be working.
If you want to try....
A window pops up
Click on "Uninstall" button below window.
You may have to confirm this. Click OK until the box closes (and may ask you to reboot - go ahead and do so).
Now,
A window pops up
Click on the "Install" button.
Click on the Protocol selection.
Select TCP/IP from the list and OK.
Click on OK until box closes (may have to reboot).
Try Internet again after the above.
Disable any proxies.
Had forgot about that one, lol.
From Internet Explorer....
<Tools>
<Internet Options>
<Connections tab>
<Lan Settings>
Make sure that the use proxy box is unchecked. <OK> a few more times until boxes close. Might need to reboot but don't think so.
<Tools>
<Internet Options>
<Connections tab>
<Lan Settings>
Already unchecked
A window pops up
Now,
A window pops up
OK went to do this and the uninstall button was greyed out with just the install button available!
Followed your instructions and then got a pop up saying "Could not add the requested component. The error is: The system cannot find the file specified"
I'm guessing this is the issue and is now a problem???
The protocol I tried to instal was titled: Microsoft TCP/IP version 6
So if Internet explorer is screwed, how do I actually do the above?
I'm using my laptop, so can I just download Crome onto the laptop and then 'somehow' copy that onto a memory stick and upload it onto the old PC?
Yes, that's correct.
The TCP/IP that you needed to uninstall and reinstall was version 4, not TCP/IP 6 (which probably isn't even being used on XP right now). I just tried it on the XP PC at work and you're right, you cannot uninstall TCP/IP (which is version 4). You may need to go to the Control Panel and then to Device Manager (System) and delete your Network adapter. Reboot and let the network adapter be reinstalled (which would then reinstall the TCP/IP stack).
