Originally posted by: Roger
It would be the same way they heated the water. You have 2 resevoirs - a cold resevoir, and a hot resevoir. The difference between the resevoirs is proportional to how much work can be done. What I'm asking is why they chose water over air?
The answer is because water has a very special property where the absorption of heat creates a very quick expansion of gas due to the kinetic transformation of the water particles. If you take a mixture of air and carbon dioxide, and apply heat to it, and then take water vapor and apply the same heat to it, which one creates more pressure within the same chamber volume?
What part of my answer do you not understand ?
How are you going to design and build a hot air boiler ?
You have a box which is
sealed to contain the pressure, you apply tremendous heat, the air expands and it is used to push pistons, now, how are you going to admit frsh air into the heat box when it is pressurised ?
In a steam engine the water is sealed in a boiler as a liquid, you do not need to keep adding water, understand ?
Now, listen carefully,
in a internal combustion engine adding water has no effect
because you are not increasing the thermal efficiancy of the engine, nor are you adding more air and fuel, this is the ONLY WAY to increase horsepower and/or torque.
