Originally posted by: aphex
Yep, that was the problem.
When it booted in safe mode it came up with the error that my ATI Radeon is responsible for the system instability. Should i try and install some drivers off the Epox cd? Or maybe even the ATI cd? It seems to be using the XP drivers, but dosent like them.
If you are safely into the OS shell, definitely get the latest drivers from ATI, or at worse get the latest from your install CD. Really odd though, with no drivers installed it should be defaulting to standard VGA mode. Double-check your BIOS and make sure nothing funky is going on in there. Disable fastwrites, go to a safe AGP mode (2x maybe), make sure that your primary VGA adapter is set to AGP (assuming you have an AGP card) and see if that helps at all.
Chiz
Edit: Oh yah, I like to disable any integrated stuff I'm not using. Onboard RAID, USB headers I'm not currently using, serial and parallel ports, midi, gameport, anything to narrow down any issues to ensure a clean and stable installation.
