Originally posted by: Vic
Of course you would. But it doesn't exactly just pop right into the Toyota's wiring harness.Originally posted by: jagec
Why in the world wouldn't you just use the S2k ECU?
And why would you use their wiring harness? If you get the front clip, you can just use the s2k wiring harness, put the ECU somewhere appropriate, and run the harness to it.
Maybe I'm missing something, but I just finished putting the engine back in my car yesterday...and the only wires I had to unplug were those to the ECU. I could have just as easily taken out the ECU, and had the whole assembly sitting in front of me. If I dropped it in a different car, all I'd have to do is fabricate motor mounts, and connect the coolant, fuel, and clutch lines, and run the throttle, speedometer, and gear selector cables. Then I'd tuck the ECU somewhere and be done with it. The only reason I can think of for other electronics would be oil pressure and engine temperature...neither of them a big deal.
