Originally posted by: Saga
So, by your explanation, the whipple is better than the Eaton mass-produced twisted roots?
Shit. Now I'm doubly confused. Doing a bit of research shows that the 06 and before Vmax (or VHO for you oldies) was the LQ9. 07 and beyond (which mine falls into) is showing the L76. Are those both Vmaxes?
I attempted to use my mind reading devices but they failed.
What vehicle?
LOLOriginally posted by: Saga
Originally posted by: Howard
wat's a twinscrew turbo?Originally posted by: Saga
Huh. I didn't know the LS9 used a twinscrew turbo as opposed to a rotary.
I'm probably wrong, it just looks an awful lot like a Whipple supercharger when everything is taken apart.Originally posted by: mwmorph
It's a positive displacement (roots type) supercharger. The marketing material will deny it, but it is very much a modified roots type with 4 lobes as opposed the conventional two which should give it higher efficiency since Roots type have never been known for their efficiency at anymore than lowish psi.
The most legendary engine of all time: The Porsche Aircooled Flat 6
What I meant was that there's no such thing as a twin-screw turbo (at least, to my knowledge).
Twin scroll turbine housing. The TST housing derives its name from the geometry of the exhaust gas inlet into the turbine. Two different-sized scrolls are generally used, a primary and a secondary. Typically, the primary is open for low-speed operation, and both for high-speed use. This creates the ability of the TST to be a small A/R housing at low speeds and a large A/R at higher speeds. TST designs are of merit in that they offer a better combination of low-speed response and high-end power. It would be difficult to configure the unit to control boost by effectively varying A/R. A wastegate is therefore still necessary to control boost pressure. Simplicity of the twin scroll turbine housing is its big selling point.
LinkIn Ford dyno testing, the "Cammer" made 616 hp at 7000 rpm and 515 lbs/ft of torque at 3800 rpm, the most power any production/race engine had ever made, then or now.
