That's what the gas+diesel generator is for.A thought occurs: how are you going to stop your big trailer of batteries without power assisted brakes? You don't have engine vacuum anymore to supply the booster.
Make darn sure none of you tell him how energetic the reaction is when you mix baking soda and vinegar. God knows what might happens if he finds out.
Doesn't that defeat the whole purpose of going electric in the first place, you know, to reduce emissions?Maybe he'll try and power his car off the stuff. I can just imagine what will happen when he gets in an accident the trailer full of baking soda vinegar erupts in a huge CO2 volcano.
Electric engine, lol.
Just go look for yourself, I'm done with your bullshit. Your "project" has been doomed to hell from the get-go.
Good question. My seat of the pants solution would be to get an electric vaccum to take the place of the engine vaccum. I have frankly never dealt with brakes so will have to come up with something if it proves to be a problem.
Also, my dad's car does not have power brakes, and it stops good enough if you are careful.
If the battery pack proves to be a problem, I could do the same thing with just solar panels. Could still generate 1000 watts on a good day and would weigh nothing.
But you'll be adding a bunch of weight, especially if you use lead-acid cells.
Like JLee pointed out, 1000watts is nothing in terms of automotive power. And 1kW of solar cells won't be cheap.
What are you talking about? A 2000 watt electric engine will easily power a car according to my calculations.
Have you looked at solar cells imported from China or Hong Kong? In bulk they are dirt cheap.
200 watts for $2.
http://www.alibaba.com/product-gs/284454643/180W_Polycrystalline_solar_panel.html
That is like, nothing.
200 watts for $2.
lolWhat are you talking about? A 2000 watt electric engine will easily power a car according to my calculations.
