Eh what the hell...UPDATED WITH CARD IN COMPUTER
Gandolf1
22
Originally posted by: AWhackWhiteBoy
Did anyone flash to the vanilla 6800U eVGA bios in here? I did and the core defaults to 425 and I have absolutely no idea why. I need my core at 420 and below otherwise i get artifacts. This is so maddening!
How could i edit the eVGA stock bios to default to its actual 400mhz speed, or maybe even 415/420? Could someone point me in the right direction?
Coolbits will allow you to select the boot and run clock.
I'm running the stock ultras bios (rev 4)
However you can mod your bios with "OmniExtremeEditFX" (I did a 1.5 volt change) To what ever voltage or clock you want.
And it is a permanent change (unless you decide you want something different)
Elfear
7,165
824
Does anyone have the FarCry benchmark tool that could run a few comparo benchies for me? I just need some framerates for Ubisoft Regulator and Ubisoft Volcano run at 1280x1024, with and without 4AA 8AF, Max detail, and default render path.
Kabob
15,248
Back in stock at Zip Zoom Fly
Did anyone get a card from them that actually came running 325/1100??
If not, did anyone actually get their flashed to run at 425/1200 or whatever the standard is now??
Rhagz
255
sitting at 430/1130 right now, artifact free, seems stable.. played a few hours of doom3, warcraft3, benchmarks.. not a single reboot or blue screen or anything.. temps around 60 (an my case runs a little warm usually).. scored a 5376 on 3d'05.
My card came 325/700 from ZZF, flashed to a GT1.5v BIOS. Very satisfied atm. :)
Standard Ultras are 400/1100 .. vanillas are 325/700 and GTs are 350/1000 (correct me if im wrong)
so anything over 400/1100 is excellent
Kabob
15,248
I just ordered one (since I decided not to order one fron newegg and I cancelled my order from ZZF once already) Out of curiosity, if I got a 325/700 card, would flashing it to the LE 325/1100 bios and then flashing it to the GT bios work??
I hope to get 425/1100 Ultra speeds without alot of struggling...but now I'm really worried (again) This would be the 2nd time I've cancelled an order from them, but ugh...I dunno what to do. If I get the card and it's running a 325/700, I can flash it to the LE BIOS w/o violating my warranty, and if that doesn't work, I can return it to eVGA correct??
johnannie
64
Well, I got mine today. 325/1100 out of the box with all 16 pipes open. Ran 3dmark03 with everything stock and got a 10040. Some slight artifacts...on the turtles back. :) I then flashed to gt 1.4. Easy as hell. Thanks for all of your work. I have been able to overclock easily 3d permance mode only with Coolbits 2 to 430/1.20. Runs perfectly. It's running pretty hot though. It has an Idle temp right now at 63 degrees (42 ambient) and when I ran 3dmark it got up to 70. Should I be worried about that? I have WOohoo.
Thanks again for all of your hard work guys.
qulAKle
233
Ok, guys can you please walk me through this. I dont have a floppy in my computer. So, I downloaded Thugsrocks and Aonics Bios iso. in the text file in this iso it tells me that to burn this iso I needto extract a BCD file. There is no BCD file in the archive. Should I make my own BCD file and extract everything into it? Thanks in advance!!!
Viper87227
730
What are you trying to burn it with. Download the trial of Nero 6 ultra, its easy as can be there. Click open CD, pick ISO from the drop down list, open the ISO you downloaded and hit burn. Took me a total of 20 minutes to burn the cd and flash the card. Thugs and aonics made it easy as can be.
Kabob
15,248
Where did you order your LE 6800 from johnannie??
Also, what do I need to do to flash the BIOS. I see a self-installing floppy bios kit, so do I put those files onto a system floppy disk or a blank one. And what do I do with the CD image for the modded BIOS. Do I just use one or the other, or both??
qulAKle
233
ok, just flashed. Everything went as planned!!! I reinstalled the 66.81 and overclocket the 3D setting to 400/1100. Works great scored 3100 with my crappy old p4 1.7 and 512 of ram. Is that a good result?Olso for everyone who missed it:
How to make your card show up as a 6800 Ultra in your device manager and other programs (Credit to Aonic)
Note: You will have to uninstall/reinstall your video drivers again after doing this.
1) Open Riva Tuner
2) Next to the gray box that says 256-bit NV40 blah blah, it says Customize on the right side. Click on that
3) Choose Low Level System Settings.
4) Go into NVStrap Driver tab, and you may have to click on install, on the bottom.
5) Where it says Graphics Adapter Identification, choose custom, and below that, in the grey box, arrow to
0040 (NVIDIA GeForce 6800 Ultra)
6) Click apply, reboot, and reinstall drivers.
Rhagz
255
You can either burn the .iso to a disk with Nero, or run the floppy installer. Burning the disk makes it bootable, you dont need to do the bcd stuff, that is what he used to make the iso/boot disc. If you use the floppy installer, just put a blank floppy in the drive, open My Computer, right click on the drive and click format to system/boot disk, run the installer and it will make it a bootable disc that autoruns the flasher menu. Great work once again fellas!
qulAKle
233
guys my bios mod creted a problem. Before the mod my temp was idle 47 and 60 when loaded. but, now after the LE-GT 1.4 mod the temp is 55idle and 80 when playin. Is this too high?
egoadk
hmm, does the info below means it is only a DDR and not DDR3?
$0100000000 Graphics core : NV40 revision A1 (16x1,6vp)
$0100000001 Hardwired ID : 0045 (ROM strapped to 0041)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR (RAM configuration 07)
$0100000004 Memory amount : 262144KB
$0100000005 Core clock : 324.000MHz
$0100000006 Memory clock : 351.000MHz (702.000MHz effective)
$0100000007 Reference clock : 27.000MHz
$010000000b HW masked units : none
egoadk
Help. I burned the ISO boot disk using Nero.
Reboot, and I get 4 options
- Boot with emm386 (compatible)
- same emm386
- without emm386
- clean boot
huh?? I choose all of them, still cannot get Aonic's menu to come up.
aonic
139
ya i didnt add those things, those came with the boot cd Stave sent me :p
just press enter
and your right about the bcd stuff, thats the stuff i did to burn the disk, instead of distributing the boot cd maker thing(thx to stave :D) i released the ISO
Rhagz
255
choose the first option, emm386.. then choose the run cd option, then let it run a little bit, after a few seconds the menu should come up.. its worked for me twice just now
AWhackWhiteBoy
1,807
For the people with the 325/700 cards from ZZF, I got a bios directly from eVGA via e-mail a little while ago that will flash your card to 325/1100. It will create a boot disk that will automatically flash, all you have to do is boot from it.
here it is
Looks like i'm going to need to RMA my card. It seems no matter what i do, my memory is totally shot. I can push the core to almost 460, but the ram won't budge past 850 without artifacts. I tried it on a different computer with adjustable rails, same crap. There is obviously something wrong with this cards GDDR and i hope i can get an equal card from the RMA.
egoadk
Yah, I let it run for quite a long time, and the menu never comes up. Any more clues?
egoadk
This is the error message I get
CDROM: Checking boot media type
System is *NOT* in emulation mode
CDROM: Trying Atapi...
UNPACK: Extracting "a:\lib\atapicd.cab"
That's it. It stops responding at the last line.
Rhagz
255
sounds like you arent running emm386.. i cant say for sure.. try a new iso burn and see if that helps
