alkemyst
- Feb 13, 2001
- 83,769
- 19
- 81
Easier said than done and I guarantee you that you'd end up treating your shovel like an ax before it gets anywhere near that far.
The problem is digging around something you can't see all of with underground obstructions which block your shovel nearly anyplace you think you can push it under to dig around.
I understand what is involved, I have removed trees/stumps/root systems this way. The largest required me digging about 6' deep and about 12' wide to remove the full root ball.
It's not easy work, but if it's beyond you, you should hire a pro.
