ItsAlive
- Oct 7, 2005
- 1,147
- 9
- 81
Yeah with 3 sticks. If that doesnt work then the fault may lie in trying to run 3 sticks in dual channel mode as Termie suggested earlier.
You could try testing these options.
Test only the Corsair stick by itself to see if it can handle the settings. If not it may be faulty or might just need more voltage. If it does indeed work then Im guessing its the dual channel mode not allowing it.
Also you could test 1xSuperTalent stick paired with 1xCrucial stick to see if the crucial can take the overclock. This way you could just buy another crucial stick for $17 and run both pairs in dual channel. Might save you some money instead of shelling out for a 2gb Corsair stick.
