How is 4/5/5/15?
No thats memory timings, I was referring to the memory FSB ratio. Setting the ram to run 4-5-5-15 would be tightening the timings which is harder on the ram. You could try setting it to 6-6-6-18 thereby lowering the CAS and loosening the ram, which would put less strain on it. Lowering CAS would somewhat lower performance tho.
Oh, by bad. What should i set to then? Look at the screen shot in the previous page, i have them set to linked.
Look at the other pic of your bios under FSB - Memory Ratio. Try adjusting those settings to bring your actual memory clock down closer to 800mhz. Im not familiar with your board and the pic doesnt show the settings available so its hard to say what options you have there.
How many sticks did you have installed when it was stable? How many after?
What ram timings? 6-6-6-18 or 5-5-5-18?
What FSB Clock?
What ram voltage?
What cpu voltage?
With the 3 sticks?I would say last ditch effort to raise cpu voltage to 1.35v. My old E8400 took 1.36v to get to 4ghz, but was cool and perfectly happy there for a couple good years.
