Originally posted by: jcossin
15C at load? No way, I never see anyone that low on load. upper 40s and low 50s are what I see everyone saying in the threads on e6750 overclocking. I'm at 29-30C at idle.
He means you need to add 15C onto those core temps because TAT assumes the tjunction max is 85C for this cpu where as it should be 100C. Read that article - all is explained. As stated above, your cores at 68 & 70 are high but not dangerous.
The onboard side has more crackling and whining noise by far than the X-Fi card. Do you think I have a bad board?
I had a similar problem with an old MSI board & was recommended to remove all cards & cables, take it out the case, blow off all dust & re-fit it from scratch. It helped a bit but it was never perfect. If it bothers you try doing this & if that doesn't help, RMA it.
