e46 m3 vs s2000 vs mustang gt
  • e46 m3
  • s2000
  • mustang gt
JulesMaximus
74,528
908
The Miata is significantly lighter than the S2K, especially if you get a base-model NA generation. 2100lbs vs 2800lbs. There is no substitution for lightness. Even the typical V8 Miata is still only ~2500lbs (or less). In my semi-professional opinion, lightness is the most important aspect for a track car's responsiveness. It also reduces wear on EVERYTHING in the car in track conditions. It's less weight to wear tires, less mass for brakes to stop, and less mass for the engine to accelerate.
The Miata's engine is closely related to a turbocharged engine, so it has all of the goodies to keep a strained engine running under severe duty. Street driven Miatas are routinely 250k-300k mile cars on the stock engine and transmission. This also means that the engine responds very well to boost, mine is currently running 12PSI on 165k mile stock internals and stock transmission, this is in the 220whp range, more than double stock power levels.The previous owner ran 14PSI for the three years he raced it. I bought my car for $2300 and have spent another $1200 on supporting engine mods and sorting things out, hardly S2K price ranges.
Parts cost and availability. I don't know what an S2K engine would cost new or used. A Miata engine will run you $300-500 used, and less than $2k shipped for a factory crate motor. I would be amazed if an S2K engine was anywhere near this cheap to replace. A quick look at TireRack shows that Miata suspension and brake equipment is anywhere from a little less expensive to a lot less expensive than equivalent S2K equipment. Tires are more expensive in S2K sizes it seems, if you can match up the staggered sizes with the same tire. With over half a million Miata's made, and an entire racing series just for Miata's (Spec Miata) there is simply amazing after market support, and lower prices parts through high volume.
There's also the esoteric benefit of modding your car. It becomes more yours every time you change something. Frankly, half the reason I own a toy car is to wrench on it, the other half is to drive its brains out. I take pride in saying, "here's my Miata, and this is what I've done to it" instead of "here's my S2K, it's stock."
I haven't had any wheel time or wrench time with any of the cars mentioned here other than a Miata. All I will say is that working in a Miata engine bay is cake compared to any other car I've worked on. There is plenty of room generally, and very few operations that can't be accomplished in a few hours. Apparently 1st timers can expect to strip a Miata of all running gear in two 8-hour days.
In terms of driving it is an incredibly nimble, balanced, and communicative chassis to drive. They'll let you know exactly what they want to do, are hard to upset, give you plenty of warning before you find the limit, and are fairly easy to catch when you exceed the limit.
All of the cars you're considering will be fun, and they'll all do well. I can think of competitive examples of each among the local auto-x drivers I race with. However, I think that a Miata will cost less to buy, keep racing, be more enjoyable to drive off-track and to work on, and be able to support serious modding if you choose to in the future.
I have thought about this a lot :D
I agree with everything you've said which is why, out of the 3 choices I choose the S2K. I like the Miata but the only one I've driven was an early 90s brand new and I thought it was underpowered personally. I didn't really get a chance to push it though.
I will say that one of my favorite cars of all time is the Lotus Elise which is under 2,000lbs and makes 190hp. Everything you said about reduced weight applies to the Elise. Too bad they are so expensive but finding used examples isn't difficult which brings the price down quite a bit over a new one. Still, it's going to be a lot more expensive than even a new Miata.
Fenixgoon
32,049
10,822
we never saw that one coming a mile away ;)
brainhulk
9,376
454
I test drove an e46 m3 smg yesterday. As someone said, it has alot of pull. But still not as much as my old evo. The steering to me felt very sloppy. The steering felt loose and disconnected with lots of lean.
So, i'm gonna check out an s2000 this weekend. I wonder if steering/cornering feel will overcome it's lack of power.
I drove my friends boxter r. with the top down, that thing is pure sex and corners like a go cart. I can't afford a boxter r. hopefully the s2000 can give me the same type of feeling
JCH13
4,981
66
Boxster S?
I wouldn't get too distracted with straight-line acceleration if you want a car to have fun at the track with. Unless the track is a 1/4 mile drag strip :awe:
Interesting article here. Read posts 12 and 13.
Driving a car at its limit on the track is a wholly different experience than driving it anywhere on the street, I find it nearly impossible to judge track performance from street driving. The best I can do short of driving a car on a track is to find an empty parking lot and really have at it.
Kroze
4,052
Why is the mustang even on the list lol. Do you like to waddle around the track with its solid rear? Not to mention it weight just as much as a pickup truck?
TehMac
9,976
e46 M3 on the track is going to be heavenly. Hands down it's the one to get.
This. Only make sure everything works. Chances are, it's already taken a beating from the previous owner. You might have to get new parts put in, which costs $$
JulesMaximus
74,528
908
Phwew, finally got that troll post out of the way! :D
ballmode
10,246
I prefer the S2000 over the miata because of the awesome stock HID lights, a modern air conditioner. Better interior. Nice 9000 rpm redline, automatic top, and a stiffer chassis.
All of this can be modified in a miata, but if you gave me 10k to work a miata or find a high mileage s2000 from 2000-2002, id get the s2000.
If my budget was under 10k, then yes miata.
alkemyst
83,769
19
It was a 9k fuel cutoff, redline was at 8.8k...only the AP1 though.
alkemyst
83,769
19
Such crucial things for a track car...
*facepalm*
When it's a 'weekend/track car' rather than dedicated track car then those things are important at times.
In all honesty if you are driving your 'track' car legally to the track, it's probably not going to be that poorly affected by a few other creature comforts.
JCH13
4,981
66
To play devils advocate:
HID lights? Enh, I rarely drive my weekend/track car at night, and any car can be outfitted with HIDS if desired.
AC? It's a convertible...
Automatic top? More things to break and it is slower than a manual top. Zero benefit on the track as you should be running a hardtop or no top at all.
Nicer interior? (I've never actually seen the S2K's, so assuming it is better) More things to feel bad about when your convertible gets baked in the sun, rained on, dusty, etc. It will happen, accept it.
Can't argue with the 8.8k redline :awe: but it does have Vtec :|
ballmode
10,246
oh i thought we were talking about a regular car you could take to the track
if you want your track toy get the miata by all means
alkemyst
83,769
19
Lol on more things to break and any car can get HIDS, props on the VTEC shout out.
Some of us can afford the finer things.
JCH13
4,981
66
To put it simply, I could quite comfortably 'afford the finer things.' However, I really appreciate having a car that I do not feel bad about thrashing on, driving on dirt roads (I'm doing a time/speed/distance rally in two weeks with my Miata, 50% dirt road, dirt road+small&controllable RWD car = sliding everywhere = epic fun) or letting anyone else drive and/or race the car with me (auto-x co-drive FTW). I don't worry when I it leave unlocked with the top off anywhere, eat food in it, or if it gets banged around a little. It's a wholly different, and much more relaxing/enjoyable, ownership experience to have scratches and dings be a badge of pride: 'hey, I got this ding when JLee biffed a cone when he drove it in that autox! that was a good time' rather than 'wahhh, my perfect paint job got scratched in a parking lot, wahhh.'
FTR I pay less than $20/mo for comprehensive insurance + 0-deductible glass policy + a couple $k of "extra part value" on my Miata as a second car. Registration is trivial, around $100. Again, this makes it very enjoyable to own as the fun/$ spent ratio is off the charts.
Just another perspective on owning a second car.
JulesMaximus
74,528
908
Yeah, I agree. I'd rather have something I drive/ride every day and don't mind getting dirty or scratched vs some low mileage garage queen M3 or Vette.
I just rolled past 2,300 miles on my Ducati and I haven't even had it 3 months yet. Haven't taken it to the track but it does get wrung out a bit in the local canyons and mountains as well as serve commuter duty.
alkemyst
83,769
19
Dude, most that can 'afford it' wouldn't be crying about a cone mishap. You are talking above your paygrade. Just the time factor many of you guys are spending to keep these heaps barely running is amazing to me. If you had the dough, you'd solve the problems properly.
I knew a guy that put a $100k modifed Supra into the canal at Moroso. He was on the phone that night ordering another. He was pissed, but that would be the case with a $500 miata beater too.
Unless you are into insurance fraud, your comp/collision is not going to cover 'race related' incidents.
It's the same as guys like me that modify a new car as soon as it rolls off the showroom. Say bye bye to most of your warranty, but I am into enjoying my cars and can pay to do so.
Sep 7, 2009
12,960
Hey Alky what are you driving nowadays
alkemyst
83,769
19
You know what I am driving. You also know I am moving on.
It's a 1998 Nissan 240SX SE. You probably won't find more than 10 as in good shape as mine in the country. I have a list in my phone of those already ready to buy it when I do sell. They approach me from time to time when I am out and about. It's one of those cars that many love. One of the biggest things is the ability for the LSx engines to fit in the vehicle actually better than the stock engine. You can put the LSx in a lot of cars, but few as factory-setup as the 240SX. Weighing in at about 2750 fully loaded, it's very light.
It's not worth a fortune, I can probably get about $7000 for it.
My next car will be in the $50k range. I am going for new again this time rather than just a weekend fun car. My commute used to be 3.5miles and I didn't have dogs when I bought it in 2004.
Yeah, I know it's taking a while but I can't even test drive the car I want yet, they supposedly will be in the showroom by the end of October. I was hoping to get my wife the 2012 Mazda 3 this weekend actually, but she's worried she will have problems with the new car and I will be not around to take care of it.
It's for the best, I just passed 6 months of getting certified in CCNP and CCNA-Wireless which was a requirement. I traveled about 2 months of that time. My travel calendar is booked the week of Sept 12th for two days, the entire week of the 19th in Georgia(I leave early that Sunday each of these next trips and get back after midnight between Friday/Saturday each time as well), the entire week of the 26th in North Carolina, the following two weeks in Georgia, I get a week off and then back to North Carolina for a week.
Maybe jot that down since I brought you back up to speed.
Oh and don't worry too much about being a little car strapped, I can handle the $80k in balance and still be well under recommended ratios.
Like a boss.
