SerpentRoyal
Banned
Originally posted by: 21stHermit
Help, what is a IHS? 😕Originally posted by: Arkainium
so I removed the IHS. This helped a ton!
Thanks
Hermit
Heat spreader.
Thanks
Hermit
Clearly not for the faint of heart!!! :shocked:Originally posted by: Arkainium
Excellent work Arkainium! Do a search for E2180 at www.overclock.net. Several really good threads to read. Guys are getting some really nice OCs with these chips.Originally posted by: Arkainium
Right now I'm stress testing at 3.6ghz (10x360) at 1.495V running orthos small ffts with temps peaking at 60C.
TAT doesn't seem to work with my setup; E2180 and Abit IP-35E. I get an error, "Error enumerating On Demand Clock Modulation support."
Anyway, initially I was using the stock heat sink which didn't do so bad actually. I managed to get to 3.2ghz (10x320) at 1.335V but my orthos load was peaking at 70C. At this point I already felt this chip was well worth the money, but I knew I could take it further.
So then I put on a TR Ultra-120 Extreme which brought the temps down a bit, but for the money I paid for it, I wasn't overly impressed. I was doing 3.33ghz (10x333) and orthos load was peaking at about 60C.
Then I decided to take it to the next level. So I lapped my hsf and cpu, but that really didn't help all that much. I got like 2-3C improvement.
Now this is where I just got foolish. I really wasn't expecting my processor to live through this, but I figured at $90 it wouldn't be a huge loss, so I removed the IHS. This helped a ton! When comparing stock to the Ultra-120 Extreme mounted directly on top of the core temps dropped by about 25-30C overall.
So now I'm trying to decide how high I want to take the vcore without frying my chip after a week. Right now I'm stress testing at 3.6ghz (10x360) at 1.495V running orthos small ffts with temps peaking at 60C.
I have a new power supply coming in tomorrow and I wonder if that'll change anything because the one I'm working with right now is a cheap 400w from my old computer. While OCing sometimes my computer restarts and I wonder if it's not enough vcore or my power supply can't keep up. I really only just got into overclocking.
If the new power supply doesn't improve my overclock, I'll probably stay at 10x360 if I deem it to be stable enough. I'll post an update after I settle and do some more testing.
Originally posted by: Avalon
Did you have to modify your TR Ultra Extreme to get it to seat properly on the bare core, or did it just work? I've got an E2140 and a TR Ultra-120, and am seeing some high temps...don't really care to lap, but if I can just hack off the IHS, I wouldn't mind giving that a shot if I didn't have to do any further modifications.
Originally posted by: SerpentRoyal
Too much heat with the Freezer? 1.4V is a very mild oveclock with those C2D chips.
Originally posted by: brencat
Rockker, that's a nice result. If you don't mind, where and when did you purchase that chip?Originally posted by: RocKKer
Please add my results:
E2180 Q712A452 @ 3.33GHz
9x370
1.4V
Abit IP35 v13 bios
AC Freezer 7 pro
Crucial Ballistix (2 x 1 GB) 1:1.20 DDR2 900 MHz 5-5-5-15 2.10v
Edit: NVM, I just realized all E2180 are MO stepping.
I agree with Serpent...with a better cooler you could probably try for higher OC if you're only at 1.4 vcore now.
67C is fine under Orthos. No issue with the way you apply the AS5. Run at the higher voltage/core speed.
I'd limit to 70C under Orthos Large mode. Wife's CPU will probably idle 90% of the time.
Well...the Abit IP35-E that a bunch of us have here is pretty cheap and should allow you 425 - 450 FSB with minimal issue. The real question is are you comfortable shelling out almost $170 for the E6550 where you're limited to a 7x multiplier? For me, even at 450 x 7 (3.15ghz), that's not a good trade -- cost per clock. It's the same exact issue with the E6320 -- you have to depend totally on FSB clocking due to the 7x multiplier. And at that price point, you could buy an E6750 with the 8x multiplier for only $10 - $15 more and give yourself a shot at 3.6ghz running 450 x 8.
It really depends what you want it for. I recently came to the conclusion that I really want a Penryn quad, but also want something to play around with for the next few months. But if you only want 3.0 ghz, I'd say you're better off with the budget chips we're discussing in this thread.
OK 70c sounds good.
I was thinking 60c was what I should shoot for. Before this I was used to OC older AMD's where 40c from the off chip thermistor (add about 20c to get on chip temp) was my target.
Runinng Orthos LM is probably the most that system will ever be stressed. I'll just leave it where it's at for a little cushion when the ambient gets higher, you know those summery days when she's stressing it with email!
SerpentRoyal I can't thank you enough for the help you have given me.
The problem is the little swinging latch on the motherboard that locks the cpu to the socket sits too high to get good contact between the core and the heat sink. So I took that latch off but I still wasn't making good contact because the screws that come with the Ultra-120 Extreme don't go down all the way. So I used some washer-like things to make it tighter.
At first it wouldn't post, so I thought I messed up. But the problem is without the latch the cpu might not be secure so you need to be careful when you mount the heatsink without it. The latch comes off really easy, so it's just a matter of getting the heat sink on tight enough to hold the chip in place.
Originally posted by: Uhtrinity
Initial results:
E2160 1.8 Ghz @ 3.4 Ghz (9 X 377), 1.4volts
2 GB of Wintec AMPX DDR 800 @ 754, haven't changed memory timing from defaults yet.
Gigabyte GA-P35-DS3L
Coolermaster Aquagate water cooling
38 - 40c under full load running Prime 95 on each core, 30ish idle.
Anyone have any ideas what bus speed this board is capable of? Running the FSB / northbridge at stock voltage atm.
Essentially the same system as in my sig with the new MB, CPU, and memory. Upgrade cost - $250
Edit:
One Core failed P95 over night, bumped the core voltage upto 1.425v, retesting
