Squalish2357
- Feb 24, 2002
- 461
- 0
- 0
Originally posted by: Wicky
I got one of these about two months ago. Anyone else annoyed with how loud they are? I took out the fan and replaced it but it's still just as loud as it was before. Anyone know how to undervolt the fan to quiet it down? I'd be tempted to disconnect the fan altogether but there is a power supply inside that I don't want to get too hot. Any suggestions?
I did find that you can cut down some of the noise by attaching a square piece of notecard in the back on the top and bottome making a "c" shape.
Try buying a quiet 80mm fan and positioning it(via tape & cardboard, or whatever you want to use) so that half of it blows into/out of the enclosure. You will get half of an 80mm's airflow at very little noise. Were you to get equivelent airflow out of a 40mm fan(or whatever this thing uses) it would have to sound like a rather loud power tool(I would say jet engine, but they don't have as much painful high frequency as high-powered small fans have).
Alternatively, look at something like this.
