Eizo mon is made in Japan.
Spec:
Sony G420S
Aperture Grille Pitch:
0.24mm - .025mm Aperture Grille pitch (variable)
Horizontal Scan Range:
30 - 107kHz
Vertical Scan Range:
48 - 120Hz
Maximum Resolution:
1800 x 1440
Recommended Resolution:
1280 X 1024 @ 85Hz
1600 x 1200 @85Hz
Input Connector:
Captive 15 pin mini D-sub 15 pin mini D-sub
Eizo T761
Center: 0.24 mm, Edges: 0.25 mm (Aperture Grill)
H: 30 - 115 kHz V: 50 - 160 Hz
D-Sub mini 15 pin and BNC x 5 (switchable)
1280 dots x 1024 lines flicker-free at 107 Hz (max) (1600 dots x 1200 lines at 92 Hz addressable)
USB Ports 1 Upstream port (for computer or another hub) 4 Downstream ports (for peripherals)
same pitch, but Eizo T761 has higher refresh rate than Sony G420S, Eizo has bonus USB hub.
The only good thing about Sony G420S is dual d-sub inputs so you don't need to buy bnc cable.
Eizo T761 is $640 at dell, Sony G420S was $550, when you're going to spend over $500 on a crt mon, why not spend little bit more to get the best? And last time where there was 20% off discount, you could get the Eizo at the regular price of a Sony, why not get Eizo?
Sony G420S seems to have a price reduction recently, now it's $430 at dell, same price as G400 now.
