Originally posted by: polarmystery
What are your fitness goals? It's funny because your progress almost seems reverse than mine. I think last time I benched on Sunday I was at 6x245 but my squats are like 4-6x225 which is really bad. My body sucks like thatAnd what's with the high reps? Are you leaning up?
Hey thanks for dropping by.
My goals are to maintain strength through the summer. I play too much basketball to really make a ton of progress, unless I felt like taking in over 5000 calories per day. How often do you squat, have you had someone check your form?
The high reps is part of a bench plateau breaking program. I usually don't go for that, but I figured why not, just to change the pace. I rarely do high reps on anything, I'm doing it more frequently later to change things up. I'm not really leaning up, I mean I'm about 8 lbs. lighter than my high weight, but that's probably from basketball.
edit: Why not make a journal on here and track your diet and routine, maybe someone (or me) could help you with the squatting. How big are you, height & weight wise?
