does splitting internet with ethernet splitter reduce connection speed greatly?
Platypus
31,053
321
Nevermind, I misread what you're trying to do, you do infact need a router
The OP was sort of confusing but if you want both computers to be sharing one external IP you need NAT and therfore a router.
RossMAN
Grand Nagus
Feb 24, 2000
78,794
266
Originally posted by: Semidevil
went ahead and added a poll as there seems to be a bit debate between some folks.
!!! YOU WANT A ROUTER, IT CAN BE WIRED OR WIRELESS !!!
Originally posted by: Platypus
Nevermind, I misread what you're trying to do, you do infact need a router[/B\
Eli
Super Moderator | Elite Member
8
Why does this need a poll?....
You need a router. A hub and/or switch will not work, unless you only want one computer to be online at a time. Whichever computer grabs the IP first will be online, otherwise.
Special K
7,098
Your poll is only making this thread more confusing. You need a router. The hub and switch will not work in this case.
RaiderJ
7,582
Originally posted by: WobbleWobble
Originally posted by: RaiderJ
I believe if you have an internet connection to share you have to use a router, just a hub doesn't "split" the outside connection.
It can actually. If your ISP offers you more than one IP, you can use a hub/switch to tap into those extra IPs.
But then you're not sharing a connection. You need a router to share a single connection.
JackMDS
29,471
387
Semidevil
3,017
okay guys, hope you dont get mad, but I found a wireless router in my closet. I connected my pc and laptop together, and voila! it worked so easily.
everything is good to go.
one question though.
what do I need to do to protect my network so no one can access it, use my connection or access my files/activities?
all I did was plug everything in and it worked. I did not install the included program. from my experience, everytime I used this routers included software, it gave me so much problems with connection, so I just plugged it in and it worked.
what do I do to ensure it is protected? I have the default windows firewall enabled. is that enough?
btw, it is an older model microsoft wireless router, mn500.
Jan 31, 2002
40,819
Alert - WEP-only router detected.
Recommended security measure - disable wireless access entirely. :p
- M4H
Semidevil
3,017
thanks guys.
I did some searcing, but I still could not find any instructions on how to disable the wireless/wep access....
any ideas?
tomt4535
1,758
Text Read through that. You can probably skip step 1 considering you plugged it in already and it works. This will secure the wireless part and get the rest of it set up good.
EDIT: Text There are the user manuals and product guides for the microsoft wireless stuff, find yours and read through them if the other link dosent do waht you want.
