Does shredded styrofoam in a car's gas tank really screw it up?
I think anything other than gas in a tank will seriously screw it up. I'm sure sawdust would work well also.
tweakmm
18,436
4
Depending on how much was used, doing so would effectivly create napalm so I imagine it couldn't be good.
Mar 15, 2003
12,668
103
Hmmm.. Interesting.. Very interesting.. Not that I would do this....
JustinGoodie
410
well, since it'll be in the gas tank, anything would really work, using styrofoam would make a bit of napalm, although it won't ignite in the tank.... pretty much whatever you use should clog the fuel filter
Rudee
11,218
I get wet dreams just imagining catching someone in the act of doing that to my vehicle. It would be safe to day you'd be left lying in a puddle of your own urine crying for your sweet Momma if I ever caught you doing such a thing. Don't be a jerk.
flxnimprtmscl
7,962
Doesn't frozen orange juice concentrate with gas (+ something else?) equal napalm as well? Anyway, there are all kinds of things that would work. But, as someone above posted, if you're planning on doing this to anyones car I hope you get caught and get your face beat in so bad your own mother wouldn't recognize you.
Iron Woode
31,187
12,712
To really annoy someone, you could put a litre or so of engine oil into the tank. That would really screw things up.
geno
25,074
4
I'm pretty sure the styrofoam will break down or be eaten away by the gasoline, and once that happens, it'll probably make the engine run funky
Rudee
11,218
In a related enquiry, what would hurt more more: Whacking a punk in the knees using a 9 iron, or a tube sock with a cue ball stuffed inside?
amnesiac
15,781
The best method is a plastic baggie.
It'll get sucked into the filter, choke the engine and stall it, but when the pump stops, the bag is released from the filter and the car works again. They'll never figure it out. :p
*note: I would NEVER do this because I don't have anyone I hate that much
v3rrv3
1,826
Too my knowledge Orange juice concentrate + gas + ??? doesn't equal Napalm. Fight Club is spreading fake stuff :eek:
- Kevin
ElFenix
102,389
8,547
i've mixed styrofoam and gasoline before and with enough styrofoam you'll get a highly viscous goo that will put out a match
cavemanmoron
13,664
28
2 cycle oil,like a whole quart,
they will think that the engine is really messed up,especially if 2 quarts are added,
to do this best,to freak your "buddy" out,
get a 2 gallon gas can,
add 2 quarts 2 stroke/2 cycle oil, to the can,
add 1 gallon gasoline.
add to your bud's gas tank,
his/her car will smoke big time!!!
Hmm;. if in California, might they get a pollution ticket..../???
MangoTBG
3,101
If you've ever been to a start hat sells hidden cameras and stuff ( our local place is called U Spy) they have the coolest crap. They have all these small vials of stuff for revenge ranging from stuff you pour in someone's drink that gives them horrible horrible gas, turns their teech lemon yellow, to stuff that's called "Liquid Scratch". I think it'd be the worst thing to do. It instantly eats away at paint and all you need is one drop. They also have a vial that if you empty it into the gas tank, when it mixes with the gas it expands to 3-4xs the volume, tearing the engine to pieces.
jlee
48,518
223
For some reason, your title cracked me up...I was like "What did who do now..."
BooGiMaN
7,955
i heard of this but with a ping pong ball
it floats until it gets sucked up then clogs the line stalls engine and when egine stops floats ight back up until it gets sucked into the line again
igowerf
7,697
I made napalm with a friend before. The styrofoam dissolves in the gasoline and it becomes a kind of thick, pulpy goo.
