Insert_Nickname
- May 6, 2012
- 4,971
- 1,696
- 136
Place cursor over number 21 and read the description:
"Two SATA 6GB/s interfaces through the Marvell* 88SE9128 controller (blue)"
Must be a mistake. The manual does not mention it.
Anyway, if you won't believe that you're running on the Intel SATA ports install Intel RST drivers and the RST application. If you can see your drive there, then it is running on the Intel SATA ports.
Since you obviously do not have an additional Marvell/MS AHCI driver installed, YOU'RE NOT USING A MARVELL CONTROLLER. I'm sorry, but I can't help if you're not willing to listen...
