Thanks Noriaki, you pretty much summed up what I posted >>
LOL!!! Sorry about that
I typed my post but then got disturbed, and turned around and talked to someone, then came back and hit the button, I didn't see your post Ace
I don't want to spend a bunch of money, and I was hoping something with integrated Savage4 would be acceptable until nForce arrives, then transfer over the CPU and memory. (If the nForce accepts PC-133.) >>
I don't know about the nForce accepting PC133....but a Savage4 could probably last you until the nForce, depends on how much gaming you do.
I've been living off a TNT2m64 for a few weeks, and it really didn't bother me that much (I got a GeForce256 for $99 canadian brand new though...so I couldn't pass it up (with TV-out to
but the m64 was actually alright since I just haven't been gaming).
Personally if I was trying to hold out on the nForce, I think a Savage4 could probably do me fine.
If I also go Intel, it means I can go with the smaller case and 150w PS. >>
You could also run an Intel CPU with a nice shiny Adda 13CFM 16dbA 60mm fan
(not sure if you know dbA that well but 16dbA is VERY quiet...~28 is average ambient noise level, 22-23 is considered a whisper....16 is less than half the loudness of 22).
Weren't people saying the KT133A's are very reliable? Almost as much as an Intel 81x? >>
I would say so AnandTech uses KT133A boards for some of it's web servers. I think they are stable enough
Only thing that bugs me is that The 133A Savage4 motherboard costs $165C plus a cheap Duron.
The Intel815 boards cost $200C plus a more expensive Celeron or MUCH more expensive P3. >>
What about an i810 though? The i815Es have integrated Video true, but really the i815 is the sucessor to the i440BX (w/ AGP4x, ATA100, 133FSB etc)...Intel tries to downplay the i815E as a high-end P3 chipset in favour of the i820, but really the i815E is the high-end chipset of choice for the P3.
Look for some i810 boards, they should be quite cheap, and the i7xx intregrated graphics is actually semi-decent for 2D and stuff. I had a PowerColor standalone i740 card in a second computer for a while, I wouldn't use it for "Quaking", but it's 2D performance was certainly acceptable.
