Do you differentiate between the colour(s) violet and purple?
TwiceOver
13,544
44
I always think of violet as being the redder side and purple as the bluer side. Same color though.
SKORPI0
18,500
2,426
http://en.wikipedia.org/wiki/Purple#Purple_vs._violet
In the traditional color wheel used by painters, violet and purple are both placed between red and blue. Purple occupies the space closer to red, between crimson and violet.[2] Violet is closer to blue, and is usually less intense and bright than purple.
While the two colors look similar, from the point of view of optics there are important differences. Violet is a spectral, or real color – it occupies its own place at the end of the spectrum of light, and it has its own wavelength (approximately 380–420 nm). It was one of the colors of the spectrum first identified by Isaac Newton in 1672, whereas purple is simply a combination of two colors, red and blue. There is no such thing as the "wavelength of purple light"; it only exists as a combination.[10] [11]
Pure violet cannot be accurately reproduced by the Red-Green-Blue (RGB) color system, the method used to create colors on a television screen or computer display. It is approximated by mixing blue light at high intensity with less intense red light on a black screen. The resulting color has the same hue but a lower saturation than pure violet.
One curious psychophysical difference between purple and violet is their appearance with an increase of light intensity. Violet, as it brightens, looks more and more blue. The same effect does not happen with purple. This is the result of what is known as the Bezold-Brücke shift.
While the scientific definitions of violet and purple are clear, the cultural definitions are more varied. The color known in antiquity as Tyrian purple ranged from crimson to a deep bluish-purple, depending upon how it was made. The color called purple by the French, pourpre, contains more red and half the amount of blue of the color called purple in the United States and the U.K. In German, this color is sometimes called Purpurrot ("purple-red") to avoid confusion.[12]
Violet
Purple
34,667
According to html named colors:
I disagree with the html interpretation.
And back on indigo:
