Originally posted by: Jeff7
Wow, I thought this was an old thread.
Flickering is subjective. Some people will complain about a 60Hz monitor flickering. Others have no idea that monitors even flicker.
You could probably solve the flickering with a few capacitors, or at least reduce it.
LEDs also can use pulse width modulation, which I think is for brightness control. I've seen quite a few LED brake lights on cars which flicker, and as far as I know, they have access to an easy source of DC.
I have no idea what a car's alternator puts out, but the battery (and its charger of course) are DC.
Simply put, heat. The "bulb" can shatter if damaged as well. They are used in outdoor / warehouse lighting where there is sufficient room for the heat effects to be mitigated.Originally posted by: ICRS
What is this lighting for if you don't mind me asking?
Also I wonder why MH (Metal Halide) lights aren't used to light homes and such, they have an efficiency rating that is higher or as high as any fluorescents. I think they give a nicer light too.
Originally posted by: DrPizza
I demonstrate AC by using two LED's. At the end of a 5 foot cord, I soldered 2 different colored LEDs in parallel, but with a resistor in series to reduce the voltage to the LEDs. I plug the cord in & spin it around in a circle. Thanks to persistence of vision, you can see little arcs of red, then yellow, then red, then yellow, then red... Only one color is on at a time, and the light is brightest more toward the center of the arcs; it fades toward either edge. One of these days I'm going to use a digital camera during the demonstration, time the number of revolutions per second, # of colored arcs per revolution (camera helps here) and calculate the frequency of the supplied power.
