Originally posted by: Mark R
Originally posted by: ICRS
What is this lighting for if you don't mind me asking?
Also I wonder why MH (Metal Halide) lights aren't used to light homes and such, they have an efficiency rating that is higher or as high as any fluorescents. I think they give a nicer light too.
MH is expensive. But there are problems with MH as well.
Flicker - They suffer badly from 100Hz/120Hz flicker - worse than fluorescent.
Expensive - Lamps are expensive, and fittings are expensive too. The fitting has to be able to withstand catastrophic arc tube failure by containing high velocity lumps of white hot shrapnel.
Ballast requirements - magnetic ballasts for MH are much bigger and heavier that those for flourescent, so are more costly and less convenient to site. They may also have louder buzzing.
Environmental - MH bulbs contain substantial amounts of mercury - 10s of times as much as CFLs, as well as other ecological altrocities (such as thallium, caesium and radioisotopes of Krypton)
Long warm-up and cool down - 5 minutes to come up to full brightness, and a 15 minute restrike time make them totally unsuitable for use where they may need to be turned on and off regularly. They're great for offices, and other public spaces - where in a home, where light may not be requried all day, this really is a show stopper.
That said, their long life and high efficiency make them good for certain markets. Round here, all the street lights are progressively being changed from sodium (both low and high pressure) to MH. Ever been to a parking lot lit by low pressure sodium? Trying to find my car was hillarious.
I light (some of) my home with MH. Personally, I use Iwasaki Color Arc Renaissance 6500 K 150 W lamps. Lovely cool color temperature, a color rending index of 96 make it acceptable for color craft work (but still not perfect, reds are a bit undersaturated). I have on of these on my bedside table, connected to a timer. It's lovely waking up a 6 am on a Northern Winter morning, and to feel as if you're lying on a Hawaiian beach in the mid-day sun.
