Question Do I have defective A memory channel ?
Mir96TA
1,950
37
I got Z590 Phantom Gaming 4 ac MB, I am trying to install pair of memory but I cant seems to populate memory channel A or just able to use A channel.
If I put any module in there it just sound like fan picks up speed and get slower.
If I use memory channel B it works fine.
Is that mean I have defective MB?7ED2F59B-4A46-4621-BBBD-C81C34652DE1.jpeg7A13DF46-29BC-4838-8329-4A4AFCE300FC.jpegA8D84591-F3AD-460F-8FAC-EB0FB35BDC29.jpeg
The memory I am using is F skills F4 3200c 14 D
Here is CPUz stuff Linkified
Thanks in advance
SamMaster
180
129
Here is the bent pin:
It is quite possible that it is barely touching the CPU, having a contact not good enough before you reseated it. It works now, but it might eventually lose contact again with heat creep.
If it was another pin, closer to the center, it would possibly touch another pin and cause even bigger issues.
Mir96TA
1,950
37
If you have not shown this circle picture I wouldn't able to see it all. (Thanks)
I wonder I should think about RMA then ?
Iron Woode
31,296
12,818
bent pins have a nasty reputation where RMA's are concerned. Most board makers will deny your RMA. It would be best to see if it could be bent safely back into position. You will need a strong magnifying lens and a pin or something equally small to do it. Nerves of steel also help.
There are videos on youtube about this.
Mir96TA
1,950
37
My hands are sweating by thinking of this.
I mean in past I have done some Socket 7 cpus ones........ these are little two small for my hands and eyes
aigomorla
21,067
3,575
umm im suprised no one commented on your ram placement.
This picture here:
You have ram in slots B1B2.
You will not get dual channel out of this config as the lanes are just not physically there for it to work like that.
In the second picture it shows you fixed the ram placement:
Meaning you have ram placed in (cpu) (gap)(ram)(gap)(ram)
which is dual channel config, and will use the dual channel lanes and also shows why it works.
It states this in the manual, to always occupy A1 + B1 then A2 + B2.
I would not worry too much about your bent pins as they look good, except possibly the lowest left pin, that looks a little bent.
But i do not think bent pins was your issue, it was most likely physical ram placement.
Mir96TA
1,950
37
This picture here:
I really think you have miss the comment I have made, I couldn’t get MB to boot if any thing occupied in Memory Channel A.
I was only able to get it to boot, when memory was memory channel B.
However after taking a CPU out and look for bent pin on a socket, which I didn’t see, but other readers on this forum saw that.
After that memory Channel A started to work by it self and with Memory channel B.
