do banana plugs work on any receiver or speaker?
Kaido
Feb 14, 2004
51,937
7,408
never used them, just used standard speaker wire. they look nice for easy disconnection. can they work on anything, or do the jacks have to be special to accept them?
rudeguy
47,351
14
61
you can make them work on pretty much anything. I find them to be a pain in the arse though.
Scarpozzi
26,392
1,780
Thanks guys....it's back in my head again. GRRRRRRGHH!!! I just got that stupid song out of my head the other day too!
Kaido
Feb 14, 2004
51,937
7,408
rofl just googled it
Kaido
Feb 14, 2004
51,937
7,408
Originally posted by: cRazYdood
I think you're looking for pins, not banana plugs.
pins? I'm only familiar with bare speaker wire, trying to find a better-looking option and one that's easier to disconnect.
Kaido
Feb 14, 2004
51,937
7,408
why? they look so much easier...
Baked
36,052
17
It all depends on your setup and placement of the cables. I use silver spades in my setup.
amol
11,680
it's the best, beats the rest, cellular, modular, interactive-odular! :D
Kaido
Feb 14, 2004
51,937
7,408
spades? I didn't even know there were banana plugs till recently. what are all the different types and stuff?
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
I think most newer stuff will work with them. Do you have binding posts on your receiver or those black and red plastic hinge sort of things (i don't know what they're called)? As long as you have binding posts on your receiver and speakers it should work.
Oh, a friend of mine with an older sony tried banana plugs but his outputs on receiver were pretty close together and the posts ended up touching each other... and the kind he got used the outside surface as one of the conductors = no good.
slpaulson
4,414
14
Pins are for the hinge connectors.
Like these
Banana plugs are for posts.
spidey07
65,469
no, they do not.
many receivers/speakers will not accept banana plugs (they claim to be 5 way binding posts but the diameter is too small for standard banana plugs)
Yes they are very easy for connecting/disconnecting.
rudeguy
47,351
14
61
they sure do look easier. Its just a pain to have to deal with screwing the ends on, then unscrewing them when your wire falls out just to have to screw them back in. Twist your ends and plug your wire in.
So
25,923
17
A plug is a plug, I use them all the time for EE labs. I don't like 'em that much, but if you move your speakers a lot, it might be worth it. Otherwise, I'd just sick with wire.
So
25,923
17
Even then, you might be better off just tinning the wires and calling it a day.
EvilYoda
21,198
9
So's first post is about right...if you can use them, great, but unless you're changing and moving speakers/hardware every week, just use the bare wire.
slpaulson
4,414
14
You're probably better off soldering them in, if possible, rather than screwing the wires in.
rudeguy
47,351
14
61
you have to screw the wires in...thats what holds them inside the pin
