cliftonite
Whats kind of size can you achieve on that thing with a throw distance of only 10ft or so?
Originally posted by: edfcmc
whats wrong with the free plans available at www.diylabs.org where you bought some of your parts?
How are the $20 plans better?
Originally posted by: dman
400W for the light seems like a lot, but looks like avg projector uses 200w power. Still, for DIY, I would wonder if the heat from the lamp would hurt the LCD over time, cause it to go bad sooner, etc? On the plus, you could upgrade the LCD in a few years to a nicer model and get better resolution for less than a new bulb on most projectors would cost.
Also, you mention being able to 'see the pixels'? Seems to me like you have the screen to big or you are sitting too close. That would be annoying to me... or were you just saying that if you got closer you could see them clearly, but, at normal viewing distance not really noticeable?
Nice job, but, wife would never go for it... too ghetto. Wish we had basements in S.FL... <sigh> 😛
Originally posted by: PhasmatisNox
I picked a nice LCD projector unit out of the trash at school today. It's one of those units that sits on top of an overhead projector and hooks up to VGA as a 'cost effective' way of using an existing projector. I'm not sure if it works, but if it does, would it be useful for making something like this? Thanks.
It would completely depend on the specs of the panel. I would imagine school property that was just dumped and it being an old vga panel would mean you'd get a pretty crappy looking image to be quite honest. I don't see why you couldn't get a projector up and running, but you really shouldn't expect much. The better the strippable lcd and optics the better your image will be.
Heh, I just looked up the model, it's a super-low res black/white. I'll find a use for it...
Thanks for the info.
Originally posted by: 0roo0roo
http://www.tomshardware.com/howto/20041113/index.html
http://www.tomshardware.com/howto/20041201/index.html
Originally posted by: quakefiend420
looks good OP :thumbsup:
i'm going to build one of these as my next project
That's interesting. Never thought of doing it that way....
Btw, I found a suitable reflector and decided to go with the Fusion HDTV 3 tuner for OTA HDTV. Super Bowl goodness. I'll post pics with results when this stuff comes in.
What made you choose the Fusion HDTV card? Did you look at the ATI HDTV Wonder? I personally have not used the Fusion card, but I do have the HDTV Wonder. For me, it works wonderful. It does have its bugs, but it should be fixed in the near future with driver updates. However, I might look at the Fusion card if it is better.
