Originally posted by: DBL
Originally posted by: Spudd
Originally posted by: Crazymofo
That is dirt cheap for that large of a screen.. now all you need is a sound setup for movies...
Yeah, that's why I gave it my best shot. The idea that the bulbs on the commerical projectors can cost hundreds of dollars and only last a few thousand or hundred hours was the decision maker. The bulb I'm using is 400Watts, gives out 33,000 lumens (of course only a fraction makes it to the triplet after hitting your LCD) and lasts 20,000 hours--and only costs $37 to replace.
I assume you could do this with a 1600x1200 lcd if it wre easy enough to strip? That would be quite a deal considering the cost of a projector that supports that type of resolution.
Yes, I don't see a problem. As long as the width and height of the LCD are below that of your fresnels, and you can strip the monitor. The biggest problem with stripping them is the ffc cables--they break very easily. Delicate touch is necessary, but since this is a tech community, I'm positive most of you are more than capable of stripping the lcd.
