JulesMaximus
- Jul 3, 2003
- 74,586
- 986
- 126
Originally posted by: ThisIsMatt
You really don't think I can pedal 3 revolutions in a second? Maybe you're just slow...get over itOriginally posted by: JulesMaximus
11 rear, 44 front. Yes, steep hill, yes my cyclometer is configured correctly (and I've compared it against my car), yes I'm passing traffic. I don't have clipless, but I do have shoe straps/baskets/whatever you want to call them, and yes it takes a lot of pedalling. FYI, it was 47.6mph to be exactOriginally posted by: JulesMaximus
I use the top end of my mtb when on road all the time, getting up to over 45mph. I use the low end when offroading quite often as well.Originally posted by: FrankyJunior
Very rarely will you ever use the very top or the very bottom gears so for standard riding it won't make a bit of difference.
I have 53 teeth on my big chainring on my road bike and 11 on the smallest rear cog. At 42mph (I hit that on Sunday going down a huge hill near my house) I could barely keep up if I pedalled. I seriously doubt you have a 53 on a mtb so you must have been spinning at a cadence of what...130? I can do 100 fairly smoothly. I call shens.
Edit-You sure you have your cycle computer calibrated for the correct wheelsize?![]()
Checking this calculator Text, with your chainring/rear cog, 26" tires and 170mm cranks, 120rpms is (only) 37.1mph.
Another source says if you're running a 26" x 2.25" tire (with the standard 2115 mm circumference), you'd have to pedal at 149 rpm to reach that speed, according to the Gearing Calculator built into Cyclistats.
Again, shens.
Now, if you're saying you can coast downhill at that speed? I might be inclined to believe you...it would have to be a pretty steep hill though.![]()
I generally spin on the 53 on my road bike and vary between the 17-19-21 tooth cogs on the cassette. My cadence is around 90-100rpm and speed is around 20 on flat roads. Not exactly tearing it up and certainly not race speeds but I get a good workout at that speed and cadence. People I've talked to who race say you really have to train hard to be able to pedal smoothly at 150-170rpm. Unless you're a racer or semi-pro cyclist, I don't think you can pedal 3 revolutions per second.
