DFI CFX3200 + Opteron 185... need help
well finally got my computer up and running... but apparently it was the graphics card that was the problem... both my cards arent working for some reason
i just put in my old asus n6600 card in and it works fine...
ill just have to switch this cpu to my other platform on the asus...
That sounds like a power supply problem to me.
edit: Assuming you didn't totally screw up Windows, in your attempts at overclocking.
notihng was wrong with windows... well.. it took a few mins for the computer to recongnize the keyboard and mouse... and xp not recongnizing my grapics card... guess its a lil too old.. =p
but yea... my power supply? it was just a minor increase for voltage...
so i guess its this motherboard thats a pain?? or the cpu? or both? =p
Sure, low voltage is the fastest way to kill comonents, except for voltage spikes, and magnets. What power supply do you have in that system?
edit: Oops, if it's still the 580 watt Hiper, it's not likely the psu. You should still download SpeedFan, and find out what your temps and voltages are, though.
will do =) so whats a normal temp and voltage?
Your +12v should be as close to 12v as possible, but not lower than ~11.6v, your +5v should be 5v, but not lower than ~4.8v, your 3.3v should be 3.3v, but not lower than ~3.1v. And your cpu temp (Temp 1 in SpeedFan) should be 30C-40C @ idle, and 50C or less while running Orthos small FFT's. << at stock speeds
Originally posted by: doggyfromplanetwoof
<div class="FTQUOTE"><begin quote>Originally posted by: myocardia
Running it with the jumper in the clear CMOS position can and will damage the motherboard.
</end quote></div>
I never ever heard of that.
I'm not sure how common it is, but I've read it in a few mobo manuals.
</end quote></div>
How could it not damage the motherboard? That jumper only exists to create a direct short between the + and the - portions of the part of the motherboard that supplies the CMOS with power. Direct shorts are bad for electrical/electronic devices.😀 A few of the high performance motherboard manufacturers, the ones that actually provide documentation with their boards, like DFI & MSI, usually mention it somewhere in their manuals.
