Design changes in Zen 3 (CPU/core/chiplet only)
moinmoin
5,248
8,463
It's a little less than 2 years since the thread on design changes in Zen 2. It's unfortunate that even a month before the public launch of the first Zen 3 chips we still don't get any meaty information, but with the event we at least got some rough outlines which areas were changed and what their impact is. I hope AMD will fill in the interested public come time.
The 19% IPC improvement broken down into the different areas:
Doc used his pixel counting skill to come up with these numbers:
  • +2.7% Cache Prefetching
  • +3.3% Execution Engine
  • +1.3% Branch Predictor
  • +2.7% Micro-op Cache
  • +4.6% Front End
  • +4.6% Load/Store
The first and essentially only Zen 3 leak, unified L3 cache per CCD, was confirmed:
  • Advanced Load/Store Performance and Flexibility
  • Wider Issue in Float and Int Engines
  • "Zero Bubble" Branch Prediction
More technical details to come, hopefully soon.
  • "most likely an additional int unit and fp unit, taking it to 5x INT, 3x AGU, 3x FP" via #3
+4.6% Front End
+4.6% Load/Store
  • higher Load/Store rate (Zen was 32B/cycle Load and 16B/cycle before while Intel Skylake featured double each) via #9
uzzi38
2,746
6,655
Thanks @DisEnchantment.
We finally have some die porn now:
For comparison, the cores from Zen 1 and Zen 2:
Notable is that with Zen 2 the aspect ratio of the area didn't change, while with Zen 3 it did. (Also to me the debug/wafer test area seems huge, but that's uncore stuff of the CCD so off topic here.)
Somebody willing to do some pixel counting comparing the core sizes?
Zen 3 core size in area looks to be 3.2mm^2 without L2, 4mm^2 with L2. Both up 0.4mm^2 vs Zen 2 cores, so unsurprisingly L2 size has remained tthe same
moinmoin
5,248
8,463
Thanks! So the core size without L2$ increased by a little under 15%, sounds good. Pretty much in line with much of the IPC increase (and very effective with SPECint2006).
CakeMonster
1,650
827
Do you think there could be any difference in the actual physical transistors? Or does the same process mean its identical? I'm referring to the very interesting video Der8auer did comparing Intel's 14nm+++ and Zen2 with actual microscope images.
