- Dec 21, 2015
- 980
- 272
- 136
Worse of course I have the 9020 Mini Tower and they sent the small form factor board which has one PCIe slot instead of 2. I might be able to get it to work but that's not the point.Hey is it better specs or lesser?
I know right. I had put this power supply in it and it worked fine so the 24 to 8 pin power cable is ok. I pulled it so I could use the EVGA in another system and replaced it with the Thermaltake. The system powers on and all the fans spin up but the system won't post. It gives this LED error code. Pulled one of the memory modules and it posted. Just glad it wasn't an incompatible power supply. So once again some memory issue. I'm doing a CPU stress test, ie running Handbrake which runs all 4 cores and 8 threads at 100% for a couple hours. Then I'll check the other memory module. Then replace the MB. Fun.Well, can't say you didn't find a project.![]()
- | - | 2, 3 | two blinks followed by a short pause, three blinks, long pause, then repeats. | Bad Motherboard, Memory, or Processor |
