DELL 2005fp a solid product?
crimson117
2,094
Originally posted by: NarcoticHobo
So should I return my for a replacement... the lighting is nowhere near as bad as the picture in that other thread and I have none stuck or dead pixels at all.
I think I'll try watching a dvd and see if it is annoying.
That's the best way to do it... everyone has their own preferences and each monitor is unique.
Insane3D
19,446
Originally posted by: Naustica
Originally posted by: Insane3D
I was deciding between a 2001FP, 2005FPW, or a NEC/Mitsubishi 22" AG CRT. After examining everything, and considering I had the room, I went with the CRT.
1600 x 1200 @ 100hz, 2048 x 1536 @ 85hz
No dead pixels, ghosting, or "screen door effect" to worry about
It will last me awhile, and I'll wait on LCD's to get bigger, faster, and cheaper.
But now you got to worry about stuff like geometry, convergence, and moire. ;) Not to mention you need very good VGA card to get crisp 2D in analog at high resolutions.
NEC 2141 is very good choice. I had a hard time choosing between the NEC 2141 and Sony G520P. I went with the Sony but it was a touch decision and basically a coin flip.
Well, from my POV, the NEC is basically considered the top AG monitor at the moment, and my much older 19" KDS AG's do 1600 x 1200 @ 85hz with no problems with geometry, covergence, or moire, so I'm fairly certain it won't be a problem with the NEC.
I also hear that their windows based Naviset software makes setup a breeze, and if that fails, their are focus port on the sides for ultra fine tuning. I fully expect to have to deal with the frustration of adjustment and fine tuning, but I will really only have to do it once.
As for the video card, I have two 9800 Pro's and one 9700 pro's in my systems here, and they don't seem to have any problems up to 1600 x 1200. The only thing I'll likely do in higher resolutions is game occasionally, and things you mentioned that might occur @ the highest resolutions won't matter as much. I doubt I'll run my desktop @ 2048 x 1536..:p
It basically boiled down to, other than size, space, and power, there was really no advantage to the LCD over a high end CRT. From a purely graphics quality standpoint, their really was no LCD at a similar price that could even begin to compare. Also, CRT's are clearly on the way out, at least in their current form, and LCD's are quickly getting cheaper, better, and faster, so going with the CRT now, and waiting until there are affordable LCD's that can match or exceed my new CRT's performance seemed like the best thing to do.
bjc112
11,460
Hope you like it..
Any more updates on the 2005fp?
Hopefully they start with a new revision from A00 ( or so i think )
Insane3D
19,446
Originally posted by: bjc112
Hope you like it..
Thanks...just got it and it's AMAZING. No deeper than my 19" CRT, but a much bigger, clearer, brighter screen. Superbright + gaming = teh winnar.
I'm sure the 2005FPW is a great screen, you will enjoy it.
johnnyjay
25
An update for those considering this monitor.
Just tried out my third 2005fpw the backlight issue is still present but barely noticeable. It was not evident on boot up like my first two. It has 4 stuck pixels only viewable when the screen is all black.
I'm going to keep this one.
bjc112
11,460
Hmmm.. Minor backlight Issues and 4 dead pixels?
If it's not to bad then i agree keep it.. Buuut :confused:
johnnyjay
25
Two exchanges and close to two hours on the phone with Dell in two weeks for an almost perfect monitor is good enough for me. It might take a dozen exchanges and hours of phone calls to find a perfect monitor. It's just not worth the extra hassle for me.
As for the stuck pixels only two of them are noticeable.
