Originally posted by: Souka
Java Cafe
For a 40gb usb solution...just get this...
40GB drive $62.50 w/3yr warranty
http://www2.newegg.com/Product/Product.asp?Item=N82E16822144374
2.5" USB Enclosure $13.99
http://www2.newegg.com/Product/Product.asp?Item=N82E16817155704
For about $80..... you get a 40gb 5400rpm portable, USB powered device.
I don't know about the apricorn solution's power requirements....it may just work fine via usb only.
For other USB enclosures at newegg, use the below link.. I sorted by "Best Rating"
http://www2.newegg.com/Product/ProductL...nclosure&Order=rating&CompareItemList=
Java Cafe
That's quite a temperament you have.Originally posted by: Souka
for espionage...you dumb*ss.... I'd get this....
my espionage comment is from the origninal post.....palm sized is too big... and I did state the unit I mentioned is bigger.....u dumb*ss.
Originally posted by: emeraldsky
Really? What do you recommend?Originally posted by: Souka
kinda big for espionage....
Your 40gb portable solution is cool, but it's not quite pocketable. Yeh, it'll fit in your pocket, but it's kind of heavy and it's just not practical to carry around that way. And if you take it out of your pocket to give it to a friend it's gonna look kind of conspicuous and suspicious.
if 8gb is enough capacity http://www.supermediastore.com/8gb-usb-flash-drive-flash-drives-buslink.html
if 1gb is enough...and it's the smallest around...period... http://www2.newegg.com/Product/Product.asp?Item=N82E16820214009
